Upgrading Engine Ideas >
Old 08-25-2008 | 08:58 AM
  #51
Knot 4 Me's Avatar
Originally Posted by RJBBC
The motor is out of the boat and partially disassembled. Cylinders and heads look good. The low compression in some cylinders is from valves failing to fully seat, but why? Included here are pictures of the shortblock, heads and the intake valve from cylinder 8. What do you think?
Why? That would be a good question for the person that did the head work and remapped the ECM. You should have gotten a lot more hours out of that upgrade. I still wonder if you were leaned out until the fuel pump that should have been on from day one was added.
FYI. Eickert is now located in Easton, Il. My dad has already seen the dyno room. I asked him to inquire whether or not they are willing to take on smaller side jobs such as your boat and Pratt's boat or if their focus is solely on Onken Racing endeavors.
Knot 4 Me is offline
Old 08-26-2008 | 08:12 AM
  #52
RJBBC's Avatar
Registered User
Do you have a phone number for Eickert?
RJBBC is offline
Old 08-27-2008 | 09:17 AM
  #53
Knot 4 Me's Avatar
Bert, should be a good time next week visiting the shop and seeing what Keith has to offer.
Old 08-27-2008 | 10:17 AM
  #54
KAAMA's Avatar
Thanks KAAMA. I have already sent 10x a message.
If you can get KE to do it that would be great, but did you speak to Frank about it yet???
KAAMA is offline
Old 08-28-2008 | 06:32 PM
  #55
RJBBC's Avatar
Registered User
Originally Posted by Chris Sunkin
Could be too tight of stem clearance. have you changed anything on your cooling system? Lost an impeller or had a cooling issue? Heat makes exhaust valve stems expand. More heat- more expansion. Too much and they can gall and sometimes stick. Also, bad fuel or a lean condition in the fuel system can cause excess heat- leading to seat erosion and valve tulip-ing. Check to see if they're all the same length.
Mr. Sunkin,
You and Vinny were correct in thinking seat erosion or valve seating may be an issue. The machine shop inspecting the heads mentioned the valve seats last grind job were less than optimal. I am almost wondering if the grind job was performed by a young apprentice, but speculation is dangerous. I am happy to have a $150 valve job fix the problem. Now back to finding a new motor.
RJBBC is offline
Old 08-28-2008 | 08:08 PM
  #56
Vinny P's Avatar
I hate the winter!!
Rob,
Well.... The good news is you can repair the heads, re-assemble that 454 and sell it off as a working engine. Good luck with the new engine. If you ever want to talk about combinations, drop me a line. My 540 may not be the best one out there, but its a damn good one.
Vinny P is offline
Old 08-29-2008 | 05:08 AM
  #57
RJBBC's Avatar
Registered User
Originally Posted by Vinny P
Rob,
Vinny,
I will give you a call.
Thanks,
Rob
RJBBC is offline
Old 08-31-2008 | 04:48 PM
  #58
RJBBC's Avatar
Registered User
Any thoughts or experience with a TCM 620?
RJBBC is offline
Old 08-31-2008 | 11:11 PM
  #59
Registered User
Too narrow a valve seat face on the exhaust will definitely lead to premature failure. When you get them back, run them with a dab of surface blue and look at the contact points to confirm they have enough surface.
Chris Sunkin is offline
Old 09-04-2008 | 04:26 PM
  #60
RJBBC's Avatar
Registered User
Default Onken Racing/Keith Eickert Pics
Here are a few pictures taken yesterday at Onken Racing/Eickert Engines. I want to thank Jeff Sheary for setting the field trip up and Donnie Onken and Keith Eickert for showing us around and sharing some of their current projects.
Attached Thumbnails Upgrading Engine Ideas-eickert-engine-1.jpg   Upgrading Engine Ideas-eickert-2.jpg   Upgrading Engine Ideas-eickert-3.jpg
RJBBC is offline
