Cog drive for 2.3 Whipple ???? >
Old 08-11-2008 | 05:43 PM
JasonSmith's Avatar
Default Cog drive for 2.3 Whipple ????
Can you get em? Does Whipple offer em? All for the 454/502 MAG MPI motors.
JasonSmith is offline
Old 08-12-2008 | 12:59 PM
Whipple Charged's Avatar
No, its to hard on front bearings and friction drive style coupling.
Whipple Charged is offline
Old 08-12-2008 | 04:01 PM
JasonSmith's Avatar
What are your suggestions to extend belt life?
Old 08-12-2008 | 07:28 PM
Work more...........boat less
If its any consolation, I used to go through a 10 rib belt on my 525SC at least every season.
Griff is offline
Old 08-12-2008 | 10:14 PM
JasonSmith's Avatar
I change belts about 3 times a season. If I am going to run hard at an event I change it before hand.
Old 08-13-2008 | 02:36 AM
If your going through belts that often, your simply running too small of a OD pulley, which creates more heat on the belt. Then you have to factor how fast the blower is spinning. 3 belts a season is far above normal, 1 every 50 hours would be average. Not much you can do, run a gates belt only, they work the best and last the longest, other than that, there's not much that can be done without knowing all the details. Cog will last far less time and will kill the compressor sooner or later.
Dustin
HARDCORE A/O
7
05-27-2007 09:48 AM
pirata
Donzi
2
02-04-2007 11:10 AM
thayes11
0
10-02-2005 12:36 PM
Wally
06-23-2003 02:25 PM
panteraracin
3
02-07-2002 10:36 PM
