-   -   Fuel Consumption (https://www.offshoreonly.com/forums/general-q/193550-fuel-consumption.html)
ciaoderhead 08-20-2008 09:04 AM
Fuel Consumption
I have 575sci's with Whipple intercoolers. These engines have always burned fuel evenly (within 1-2 gals on a tank of gas). Previous fill up one engine burned 12 gals more and this fill up it burned 19 gals gallons more (120 gal tanks). No extra soot in the tailpipes or black smoke. Checked the fuel tank valves to make sure nothing got bumped.
Any obvious things/areas to check? Thanks
Edward R. Cozzi 08-20-2008 09:35 AM
Is your boat stored where gas can be stolen?
verbi69 08-20-2008 09:36 AM
Whatch the kids with those lawnmowers.....They always have gas.....:evilb:
ciaoderhead 08-20-2008 01:13 PM
Nope, it was in my shop the first go round. second time I watched one gauge hardly move and the other I could see dropping quickly. Went a filled up and came up with 19 gal diff.
Edward R. Cozzi 08-20-2008 02:46 PM
The last time I ran across something like this it was a Cigarette where someone messed with the cross-over valves and both engines found it easier to pull from the same tank.
Turbojack 08-20-2008 06:07 PM
One prop has damage. Try swaping props, just be carfull how boat handles.
one motor has a problem, plugs, bad injectors (if injectors), bad valves or ???
Are both throttles run side by side or now you have to have one further forward then the other for the same rpm?
Both tanks getting topped off?
ciaoderhead 08-21-2008 09:31 AM
Throttles are side by side and I have not noticed any change in performance. I have another set of props I can try but they look fine.
I guess leakdown and compression checks are in my weekend forcast. Maybe swap MEFI and/or Throttle bodies??
michigan troll 08-21-2008 11:24 AM
If the motors are injected, check the air temp sensors. They do go bad.
ciaoderhead 08-21-2008 12:01 PM
Thanks, will that show up as a code in MEFI?
ciaoderhead 08-23-2008 08:36 AM
Thanks MT. The sensor was unplugged. I hd a few stern words with my mechanic.....ME:angry-smiley-038:
