X Dimension
Old 03-04-2002 | 11:23 AM
sambryce
Question X Dimension
Could someone help me out and tell me what the "X Dimension" is exactly? I've read a lot of posts referring to it and haven't quite figured it out.
Old 03-04-2002 | 12:03 PM
Official OSO boat whore
Simply put, it's the vertical height of the engine and drive. The higher it is, the faster the boat is (generally) and the harder it is to get on plane. The vice-versa is also true.
Cord is offline
Old 03-04-2002 | 12:04 PM
Bruce
X-dimension is the vertical distance from the bottom of the boat or the keel, up to the crankshaft centerline, measured on the transom. The larger the X-dimension number, the closer the propeller shaft is to the water surface. It is widely accepted that raising the X-dimension one inch, will increase the speed approximately 2 mph.
Old 03-04-2002 | 12:28 PM
X dimension is the measurement everyone talks about because when the manufacturer drills the hole for the drive, that's the number he uses. But the important number from the functional point of view is the distance of the propshaft below (or sometimes above) the bottom of the hull. The object of the game is to reduce gearcase drag as much as possible, without losing thrust because your props are no longer in the water. This game involves almost as much time and money as the "increase HP without blowing up" game. Right, Bruce?
tomcat is offline
Old 03-04-2002 | 01:13 PM
sambryce
Smile
Gotcha.....I get it now. Thanks everybody.
Old 03-04-2002 | 05:27 PM
blue thunder's Avatar
So I would guess it is natural for twin engine applications to have a higher x dimension due to them being off to each side of the keel centerline? What affect does the X dimension have between twins and singles?
BT
blue thunder is offline
littledcsrodshop
Active Thunder
13
05-07-2008 09:33 PM
Black Wishbone
Sutphen
4
03-11-2008 07:02 PM
40FlatDeck
Skater
10
01-11-2007 10:28 PM
375stinger
Cigarette
0
11-10-2004 04:56 PM
Bajaforce
Baja
2
03-05-2003 08:09 AM
