Iron Heads
Old 08-22-2008 | 10:03 PM
Default Heads
Originally Posted by Chris Sunkin
Yep- the Iron Eagle's are about the best. If you meant OEM, the 990 casting is about it. The 088 is good too- probably what was on your motor.
I have a great et of 088 heads. ported and new Crower springs. Iconel valves 1.94 and 2.25 valves. I built them for a 700+ HP blower motor and then went aluminum. A perfect bolt on $1000.
$1,000.00
Bob
RBeyer is offline
Old 08-24-2008 | 08:25 AM
BillR's Avatar
OSO Moderator
As you know - been thru this real recently.
The IE heads are real good. But supposed to be better ane the Edelbrock heads. PLUS they are like 70lbs lighter and build good HP. I have talked to lots of folks that have them and no issues thus far.
Have you pulled the motor out and/or torn it down yet?
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 08-24-2008 | 09:42 AM
Does this all apply to the dart alum heads?
MILD THUNDER is offline
Old 08-24-2008 | 09:44 AM
Registered User
About the best thing you can say for the Edelbrocks is that they're lighter. Nice price too.
Hand porting a cylinder head is not the most economical way to make power. It's on par with and sometimes more expensive than CNC. And the result is only as good as the person doing the work. There's much more to it than making the holes bigger.
But done right, the results can be impressive.
Chris Sunkin is offline
Old 08-24-2008 | 04:26 PM
boatfreak's Avatar
While you guys are talking heads what do you think about Pro Toplines? I just had to replace one of mine due to a few cracks.
boatfreak is offline
Old 08-24-2008 | 04:37 PM
Registered User
They were a great head a few years ago. Head technology moves fairly fast Plus, they were bought out by RHS a while back.
Old 08-25-2008 | 09:47 PM
Originally Posted by J.B. Marshall
Wow! what kind of motor work (maintenance) did you do to get 950 hrs out of them?
Amsoil every 20 hrs and valve springs every 200.
formula 382 sr-1 is offline
Old 08-25-2008 | 09:50 PM
Originally Posted by KAAMA
950 hours on a pair of Merc HP500's is pretty good---I'm sure they're gettin' pretty tired. Also, if you're looking to do a cam change/upgrade call RMBuilder/Bob Madara of Marine Kinetics in N.Y. He will get you the correct profile that will work the best for your application and what you want to do with the boat. 585-654-8583
Yes they are tired we lost 7 mph over the winter. And yes Bob is on my list of people to call.
Old 08-25-2008 | 10:06 PM
We are looking at a lot of parts Edelbrock, Dart (Alum. Iron ) World ( Merlin II ) and AFR's . So many parts so many inputs. We just want to make the right choices ,I DO NOT want to do this twice. We run mostly in salt water so will aluminium hold up for another 12 years as the past heads have ?
Thanks again for all the help.
Joby
To many parts to little MONEY!!!
Old 08-25-2008 | 10:13 PM
Not yet , But when it came apart it did not sound good. The temp went to 165 and oil pressure went to 10 before we shut it down. We were running @ 4500 when the temp started to go up. I should have been watching the gages a little closer.
