Propshaft dyno? >
Propshaft dyno?
Propshaft dyno?
Old 08-24-2008 | 12:07 AM
Default Propshaft dyno?
I would like to dyno my boat to see if it is putting out its rated hp. Is there any places that this can be done w/o removing the engine in the upper midwest?
cass236 is offline
Old 08-24-2008 | 01:34 AM
hillbilly24's Avatar
There are VERY few shops that have a prop dyno that is actually designed to accurately measure power. Most of them are fairly simple devices, they consist of a hydraulic pump, a variable valve and a gauge. The operator adjusts the valve so that the engine is held to it's max operating RPM when at full throttle. You can then take a pressure reading from the gauge. Most shops, including the one I am employed with keep track of these readings in a log book and can use them to compare future readings with. As long as you are running stock power or have an engine with some pretty common mods it shouldn't be a big deal to find someone in your area that has some base line numbers written down to compare yours with. Just call some of the higher end marine service places around you and at least a few of them should have a prop dyno.
hillbilly24 is offline
Old 08-24-2008 | 09:45 AM
hmm.. why don't they make one with a load cell? Use the ground as the anchor point, anchor the boat, and the dyno to the ground.
Joe92GT is offline
Old 08-24-2008 | 12:25 PM
International Dyno is in the process of designing one with a load cell, we actually just had the the prototype at our shop for a month or so to test. There were a few issues and they are working on them then they are supposed to send us a revised version for additional testing.
Old 08-24-2008 | 01:35 PM
J-Bonz's Avatar
Land & Sea.................
http://www.land-and-sea.com/prop-sha...arine-dyno.htm
J-Bonz is offline
Old 08-24-2008 | 03:01 PM
Full Throttle Marine in Spicewood Texas has one..
Here's my boat running on it......
......well, sort of running.....
.....and yes, it is a "Land & Sea" one...
Doug
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/qqbCMwEW134&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/qqbCMwEW134&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Boatally Insane is offline
onesickpantera
08-21-2007 06:56 PM
BajaRunner
0
05-26-2006 05:09 PM
Intolerant1
23
04-01-2005 09:57 AM
BAD-HABIT
0
06-23-2002 01:53 PM
Intolerant1
02-07-2002 03:10 PM
