distibutor
Old 08-25-2008 | 12:37 PM
Default distibutor
small block stroker msd ingtion put on new headers last year was wondering if anyone else is having or had promblems with moisture in distribitor or any ideas what is causin it
scarab22 is offline
Old 08-25-2008 | 09:27 PM
from what I have heard...normal with a MSD dist....Rob
ezstriper is offline
Old 08-25-2008 | 09:34 PM
Very common problem with MSD's and marine use.
Griff is offline
Old 08-25-2008 | 10:15 PM
ditto
HaxbySpeed is offline
Old 08-26-2008 | 07:47 AM
Airpacker's Avatar
seems like every MSD distributor I have had dropped at my shop from a marina is a big ball of rust inside. They obviously have a venting issue as well as cheap chinese plating on the advance mechanisms. I usually use new parts inside but I clear coat them and then corrosion block spray them before reassembly. I have thought about drilling some vent holes and screening them like I do with GM hei marine conversion units but there just isn't much room in the housing floor for it.
Airpacker is offline
Old 09-04-2008 | 04:25 PM
thanks guys i was told to drill vent hole but not sure thanks
scarab22 is offline
crmax
2
12-23-2002 09:28 PM
BAD-HABIT
1
02-24-2002 05:58 PM
