Timing retarding itself?
What would cause timing to retard 6-8 degrees under acceleration with a locked out msd distributor and the motor has cam buttons? It is a 350 with a med cam noting to crazy sounds like a chain streaching ?
Or a worn distributor gear.
Let us know what you find. |
Brand new msd distributor no problem there I think
Dont know if boats have the same thing as cars, but a knock sensor will retard timing.
no sensors on this motor lol it is a 1980's small block in a race boat
Vertical play in the disributor shaft. Could be caused by worn gear or improper shimming.
What kind of cam? Roller, solid, hyd, hyd roller? I would say it might have chewed up the gear if the gear on the distributor is not for your type of cam. Everytime I have seen chains stretch they have destroyed motors... valves hitting pistons, etc.
Just trying to help a brother out. |
Originally Posted by niceguy
(Post 2665915)
Just trying to help a brother out. Solid cam and lifters and the gear looks fine. It has bronze gear. Set the timing at 42 @idle rev to 4500 it retards to 37-38 Also @ idle you can watch the light back and forth slowly. Hmmmmm |
See if the rotor is loose on the shaft under the cap. And are you using an advance light?
motor
Just a wild guess but standard rotating motor and dist they do make counter rotating .
| All times are GMT -5. The time now is 09:07 AM. |
