Merc PCM555 Experts? >
Old 08-28-2008 | 10:49 AM
Rage's Avatar
Default Merc PCM555 Experts?
What is the output voltage of the PCM555 to the ignition coils?
Rage is offline
Old 08-29-2008 | 07:19 PM
Dave_N's Avatar
Maybe I'm not understanding the question, but the coils are not supplied power through the PCM, they are connected to splice 105 which is energized (12v) when the Main Power Relay is closed.
Dave_N is offline
Old 09-01-2008 | 11:42 AM
Rage's Avatar
Thanks, that is my answer.
If I connect to splice 105 will there be a 12 volt , 0 volt on off voltage signal when the engine is running that can be used like a tachometer signal? (The normal ECU tach signal auxiliary connection point provided from the wiring harness is apparently +5 volts/-5 volts which is not suitable for my need.)
Rage is offline
Old 09-01-2008 | 12:53 PM
Dave_N's Avatar
Splice 105 will have a constant 12 volt signal. I would suggest getting a MSD DIS Tach Driver, it connects to the coil power circuit (of one individual coil) and monitors current, then converts that to a 12v alternating signal suitable for conventional tachs.
Dave_N is offline
Rage
0
06-07-2007 01:28 PM
Rage
28
02-12-2006 03:27 PM
Rage
14
01-15-2006 07:33 AM
BillR
15
07-17-2004 12:36 PM
