Kill the beasts! >
Kill the beasts!
Kill the beasts!
Old 08-28-2008 | 07:38 PM
Default Kill the beasts!
What would be the best way to wire in KILL switches? Im running MSD dist. and blaster coils. Ground the neg. side of coil or run the ignition hot wire thru the switch or maybe theres another way? Seems like it also would be safer to wire both switches to kill both motors but not sure that can be done and still keep each ignition system independent. Thanks
redcorvetteman3 is offline
Old 08-28-2008 | 09:03 PM
ak
Default ignition kills
I wired my kill switch to a relay,that relay runs my fuel pump and 12v key power to my msd box.works great,i have heard it is not good to ground out an msd coil.
ak is offline
Old 08-28-2008 | 09:11 PM
sunchaser796's Avatar
I have wired the kill switch to ignition system. The kill switch is wired between key switch and purple wire in he main wire harness.
sunchaser796 is offline
Old 08-29-2008 | 06:55 AM
I did mine the same way, just ran it in line in the purple ignition power wire...Rob
ezstriper is offline
sleepy_pirate
28
11-09-2006 04:15 PM
PhantomChaos
11-09-2006 04:06 PM
Adrenaline Junkie
Eliminator
0
09-02-2006 07:08 PM
Dean Ferry
02-08-2002 09:04 AM
Hot Boat
02-04-2002 08:25 AM
