575sci  water temp >
575sci water temp
575sci water temp
Old 09-08-2008 | 10:57 PM
Originally Posted by Griff
In that case, maybe. I thought you were talking stock 575sci's. Oil temps are more relative. How are they???? are you running crossovers or recirc pumps???
I had the boost cranked up to almost 8# on my 525SC and still ran the 140* Tstat and recirc pump. It maintained nice consistent temps from 145 at idle to 155 after WOT runs.
so does anybody know what a 575sci is supposed to run temp wise with overdriven ( 3 1/4" pulleys) aeromotive fuel pumps and 7 lbs boost? 140* or 126*? I'll call Teague tomorrow since they sell the kit, but any advice would be appreciated. Mike
Michael Garibay is offline
Old 09-09-2008 | 06:55 AM
Registered User
I dont know how else to but this. I depends on the tune in the ecm. The engine has to reach the proper temp or the ecm will just think the engine is still in worm up mode. If you want to call someone you need to call Mark @ Precision Marine on efi and tunning he is good. Also Dustin @ Whipple
clpbs is offline
Old 09-10-2008 | 06:40 AM
Go with 140* Tstats. There is no reason to run it colder.
Agree.
mrhorsepower1 is offline
Old 09-11-2008 | 12:33 PM
Kelly O's Avatar
Originally Posted by Michael Garibay
What about with superchillers and 3 1/4" pulleys and running 7 lbs boost? Would that be a reason for running 126* stats?
AZSM includes lower temp stats in their kit to reduce risk of detonation. Their kit does not use a chiller. If you have a chiller the detonation risk should be minimized, no need to lower engine temps.
Kelly O is offline
Boater8987
6
08-04-2008 07:06 PM
86formula242ls
05-23-2006 07:52 PM
zahndok
3
01-11-2006 08:08 PM
Pmpaint1
3
04-25-2005 11:10 AM
Mrgoodwrench
3
03-25-2002 11:43 PM
