Max Oil Temp >
Max Oil Temp
Max Oil Temp
Old 03-06-2002 | 10:46 AM
Question Max Oil Temp
What is the max recommended oil temp (taken from the oil pan)?
RickR is offline
Old 03-06-2002 | 12:08 PM
If you are using mineral oil you may begin to break down the lubrication properties if you let it get much over 240 F. Synthetic oil will not break down if your temp happens to go over 240, but unless you have money on the line there is no reason to let the oil get hotter than 250 degrees. If it is routinely getting this hot it may be time to increase your oil cooler capacity. Don't go too large or your oil may be too cool to boil off condensation. The ideal situation is a very large cooler with a 220 degree thermostat. Just my opinion. Good luck.
WETTE VETTE is offline
Old 03-10-2002 | 08:10 PM
kaama82's Avatar
I quote Dennis Moore, author of "Bib Block Chevy Marine engine" He says it is perfectly normal for you engine oil to reach 260-270 degrees after a hard run. My 02 cents.
kaama82 is offline
Velocity Vector
0
04-03-2008 01:45 PM
handfulz28
6
01-29-2008 11:57 AM
GoCiggie31
7
08-19-2007 06:07 PM
snappinback
0
08-15-2006 07:51 PM
powerguy
Fountain
2
08-04-2002 05:17 PM
