496 Oil Pressure
What are you getting? after my motor is nice and warm, its very close to 20, and as RPM's go up i get around 30-35, maybe 40. And yes i know its LOW, I dont like it, however, Im told, MERC. minimum is like 3 PSI, and 10 PSI for every 1000 RPM's.
I know the Oil pressure sucks and Im very curious to know why its low, but at this point i just wanna run.
As for oil im runnin castrol GTX 20-50, Im planning to switch to Mobile 1 15-50 synthetic, anyone know if this weight is ok to use?
The determiner on oil pressure in most healthy big blocks and especaily the 496 Merc is oil temperature. If you are running on the hose idling with the coolant temp up to 150 to 160 degress you should se about 40psi idling and about 50-60 psi at 2500 rpms. If you have been out running at higher rpms in warm water and air temps at 4500 to 5000 rpms you will see about 20-25 psi oil pressure when you first pull back to idle until the oil temp starts to drop back from about 225 to 230 degrees F. its been running at.
The pressures at 4500 to 5000 rpms with this hot oil should be about 50-55 psi under load. If you operate your boat hard in poker runs or for extended periods above 4500 rpms or boat in high temperatures or high water temps I would reccommend changing out the 8" stock oil cooler to a 12" unit which will hold the oil temps down a bit and help with warmer higher continous rpms effects on 496 oil pressure.
We sell this cooler and it is configured to fit right in place of the stock cooler without re-plumbing the system for those that are borederline on oil temp with a 496 or have made significant HP upgrades.
If you are seeing 20-25 psi oil pressure and 35 -45 psi oil pressure just on the hose, you may have some mechanical issues,bearings, pump, etc and you should be careful if under warm load the oil pressure does not increase to the 50-55 psi range at 5000 rpms.
Its also assumed that your analog guage is reading correctly or it compares closely with the ECM oil pressure readout on a scan tool or laptop software.
It goes without saying that good correct weight oil is also a must , follow the manufacturers recommendations on oil weights and service intervals, oil is cheap compared to engines!
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
It looks like there are at least five people on here with hurt motors. My sonic runns the same 25 lbs oil pressure on the hose at 160 degrees and at idle that it does in the lake at 160 degrees at idle. I guess that make six of us.
