575sci Head Gasket ??
anyone know if I order the complete engine overhaul gasket kit from Bam will it come with Cometic head gaskets or something else??......... Bam part # is 27-842182A1..... I will be rebuilding both 575's this winter and want Cometics......
How many hours do you have?
Just shy of 300hrs........ motors run great and I am sure I could squeeze another season out of them but I am the second owner and just want to go through them now and have a clear head......... an ounce of prevention is worth a pound of cure......
I would buy the rebuid kit by parts. I agree Cometic is the only way. Merc uses the GM gasket.
The Merc/GM gaskets are superceded with Cometics. So, the rebuild kit should come with Cometics unless it is an old kit left on the shelf.
That's what I read on a post I found here doing a search but I just wanted to make sure......
Hey John,
Dont jump the gun yet. We have to make sure the blocks dont need to be bored before we even start to think about head gaskets. Head gaskets are bore specific. They will be out and apart before you know it. |
Originally Posted by Here's Johnny
(Post 2699050)
Originally Posted by JRider
(Post 2699740)
300hrs...surprised they have held up that long. Mine were toasted @ 200hrs. Definitely time! I would take it you are going thru the heads? And replacing the valve spring with the one that come with your new hydraulic roller blower cams? In all seriousness replacing the flat tappet cams would be a good move. If you do need to bore it bumping comp. from 7.5 to 8.5 with would definitely make more power without stressing the blower anymore. It sure is fun to spend someone else's money! Sounds like a fun project.
How much is a freshen up on these motors?
Originally Posted by bigboat28
(Post 2700406)
Any guess on cost?
My engine builder uses Fel-Pro.
Is Cometic that much better - why?? |
Originally Posted by BillR
(Post 2701587)
Is Cometic that much better - why?? I am not sure of the technical reasons of why Cometic work better, I can only say I have never heard of any failures with them. They are a laminate gasket, made up of a few thin layers to make up 1 gasket, like plywood. The thin layers are made of some type of metal. They have no fire ring as do felpros. Everyone has heard or had Felpros fail at one time or other, especially for blown engines. With the present choices of headgaskets available, I know I will never use any other type of gasket. |
| All times are GMT -5. The time now is 01:39 PM. |
