help WINTER time for Ilmor V10- >
Old 10-09-2008 | 12:57 PM
Default help WINTER time for Ilmor V10-
i have always done my own Winter Prep work on my boats but this year we upgraded to a Challenger with V10 Ilmor. i know it's a closed cooling system but it still pulls in water to cool the tank and headers. i have done some homework but wanted to hear from a do-it-yourself'er as well.
any input would be great... thanks in advance...
bmergner is offline
Old 10-09-2008 | 01:49 PM
I woudnt mess around call Ilmor and get a shop manual.
wellcrafted is offline
Old 10-09-2008 | 02:14 PM
Default call ilmor
call ilmor and ask for scott 734-456-3600
Jb-fse is offline
Old 10-14-2008 | 06:08 PM
Pg. 45 of owner's manual
- Fuel Stabilizer
- Fog Engine
- Drain each header (plug on each side)
- Remove Cooler Cover below oil pan to drain water and clean out.
- Drain Strainer if equipped
Break'inWind is offline
Old 10-15-2008 | 12:24 PM
thanks for the info, i did call Ilmor and they were very helpful. i was on the right track and feel much better hearing it from them.
bmergner is offline
Old 10-15-2008 | 02:42 PM
- Fuel Stabilizer
- Fog Engine
Do you think it would be a good idea to pour coolent into the headers and heat exchanger after the water is drained? Just for added protection?
Darrell.
DMOORE is offline
Old 10-15-2008 | 03:09 PM
Darrell.
I would to prevent any kind of potential rust issues.
x7734x is offline
Old 10-15-2008 | 07:15 PM
Darrell.
What "x7734x" said... I actually modified a 5 gallon bucket with a valve and hose connection at the bottom so I could hook a hose up to it and run it to my water pickup and flip open the valve. Then start the motor back up and suck the antifreeze from the bucket into the raw water system... same idea as you were describing, just done a little differently. You're on the right track though.
TX Tuna
06-24-2015 12:26 PM
Quent
08-01-2007 11:35 PM
DirtyMoney
12-19-2004 10:56 PM
Titan
4
12-13-2004 11:01 AM
teamsutphen
07-14-2003 10:20 PM
