Opinions on Headers
Looking to upgrade Headers from Cast IMCO Powerflow. Running Blown 540 at 900 HP. Any opinions on CMI versus Lightening versus anything else? Also if any suggestions what model?
I ran 1040 HP thorugh CMI Elbow Tops for a year, no issues. Gary Taylor puts them on his engines up to 1200 HP.
I think that they are a grea header and if you have a standard deck block and standard brove transom exhaust you can even go with the Unitops which are an etop with a welded tail and are even less money. CMI are the best, the others are good too, but they are not CMIs. |
Yeah what he said ,tried the Imcos on some 540s and then changed to CMI elbow tops and never looked back.good luck BIG Daddy
I would think that if you got enough bump stick to push 900hp the Lightnings will revert water.
I have CMI's on my 850 and like them. |
hey stormbauer how much for the imco's? [email protected]
Mercury Racing has replaced quite a few motors due to cracked CMI headers. Just check warranty claims. They are certainly not as pretty, but the cast aluminum headers by Eickert support big numbers and will not crack!
Originally Posted by scarabman
(Post 2719306)
(Post 2719306)
Salt or fresh water? DId the owner flush their engines after running?
(Post 2719306)
Dave |
Mercury headers are thinner and of a different alloy than the CMI headers. You guys really need to keep your facts straight.
I dont know of anyone that has had a failure of CMI headers, not the Mercury product!!! If you pick up a set of 500 EFi headers vs an Elbow Top, you'd see what the difference is. They are the best flowing exhaust on the market - period!! Thats why Mercury buys them, except they make them out of a less quality alloy than the SS CMI does. And they are thinner!! |
Originally Posted by Elite Marine
(Post 2719366)
I dont know of anyone that has had a failure of CMI headers, not the Mercury product!!! If you pick up a set of 500 EFi headers vs an Elbow Top, you'd see what the difference is. They are the best flowing exhaust on the market - period!! Thats why Mercury buys them, except they make them out of a less quality alloy than the SS CMI does. And they are thinner!! Give Elite here a shout, he has some nice prices on E-tops. They are worth it. I did a bunch of homework on this. |
Running CMI e-tops on 540s. Looks as though I made a good choice.
CMI Big Tube E-tops should be the best for a 900HP 540 blower motor. Strong, reasonably priced and real pretty in polished! Just my two cents.
Regards, Ray @ Raylar |
From what I have seen, in salt applications with 900+ hp big tube set ups, you get to 225+ hours with either Stellings or CMI you can get ready to start chasing cracks at the collector and flanges. Once they start developing, they just keep on coming. I haven't heard of any official studies done nor do I expect a mfg to divulge their warranty or product health numbers.
From what I have seen CMI makes two types of Headers , The ones that Leak and the ones that are going to leak . Just my $0.02.
(Post 2719366)
Besides the $$$ what are the major performance differences with the Big E-tops versus the Big Tubes? Also at what HP is it necessary to go with the stepped E-tops?
Have had imco powerflows,Eickert manifolds, cmi e tops, cmi big tubes, other than the prices, have'nt noticed any difference in performance, with them, I've had from 725hp to 1150hp, save your money.
I have not heard of a lot of CMI E-tops cracking and leaking, I cannot say that about regular or big tube CMI sweepers. Most blower motors will make better power with the big tube E-tops than with any sort of long tube header. I understand that the Stainless Marine High Torque III header/manifolds also work very well on blower motors.
Just my two cents. Best Regards, Ray @ Raylar |
Here is some CMI comparisons done at Keith Eicherts. All done on a NA 500 CI
Big E-tops - 765 HP Sport Tubes (1 7/8" ID) - 785 HP Big Tubes (2 1/4" ID) 800 HP |
Blower motors generally need different headers
I believe this post was started with the motor being a 540" blown motor. Header results for blower motors will be totaly different than those for a N/A motor. Just thought I would clarify so those not in the know would not get further confused.
Originally Posted by stormbauer
(Post 2718988)
Originally Posted by ZXXX Donzi
(Post 2719096)
(Post 2719306)
Originally Posted by articfriends
(Post 2721225)
My 945 hp blown 540 reverted water BAD with the lightning headers at idle,I switched to stainless marine 3's with 5" tails. They are big & ugly but work very well,Smitty
Lightning pipe looks like it actually has runners that are close to being equal length. I may be wrong, but as the pipes become more "equal in length" or closer to being a tuned runner length, don't they exagerate the reversion deal as they in effect, suck and blow harder? Cylinder "scavenging" is improved with a "tuned header" as well? In other words, a trade off for better performance upstairs?
(Post 2721226)
Just a reminder for anyone running a procharger,the keith Eickerts do not clear the blower at all,Smitty
My motor made 945 hp and does not have problems with CMI's. |
(Post 2721225)
Stellings......
over 300 hrs in fresh and salt water.... Pfaff 1000's |
I think all of the BIG tube ( CMI ,Stellings, IMCO, Stainless Marine ) or what ever work great and dont have issius if installed and COOLED ( again COOLED ) right.
The biggest problem they all have to fail is enuff cooling. They will all suck water back if the valves are overlaping to make power. But they only damage if not installed right. My engine always has a little salt in #7 and #8 cylinder. But never did anything to the engine because its min. As soon as you run high RPM it will not even get there its from iddle at the dock . You get the best power out of stellings or Stainless high tourqe III, thats a fact. But with the Stellings ,alot of cooling is ness. and the aluminum Stainless safe weight and have no cooling issius at all. make the same amount of power. Just what i learnd for alot of $$$$$$$$ on my $hit.:cool: |
3 Attachment(s)
Originally Posted by CPPerformance
(Post 2721579)
It is nearly impossible remember I said "nearly" to run any wet style tail pipe exhaust system at 900plus horsepower. Lightning makes a system with a water jacketed "Dry" tail pipe that will accommodate this application with no problems.
2 Attachment(s)
(Post 2721579)
Right know, and i dont mean to pi$$ anybody off.
I think the SM HT III is the best on the market, lightweight big runners ,dont break. I have seen them on 1400 HP blowermotors working great. I have seen them in blown up engines hot ass hell and still run with no leaks, act. mine :eek:. The looks of them ,,,,,,,,,,,,,i think they look great, they also make the same header for a 34 centerline , so you can fit them in there. $$$$ wise they are very in expensive too, so what is there to think about ? + Brownie at SM and everybody else there are bretty cool and help where they can. Just my 2 C, but i have seen alot of the others break. Most of them due to not enuff cooling SS needs cooling aluminum needs it also but not that much since its getting ridd of heat alot faster. Damn i'm smart. LOL:drink: |
Probably the bottom line in this decision is what are you trying to accomplish and at what cost. If you are looking at maximizing hp then in a naturally aspirated application you should be looking towards a "tuned" exhaust with at least equal runner length? To say all are created equall is BS. There have only been a couple actual comparisons done and that was back in the 97-98 time frame. I believe Fountain hired Innovation to look at some different offerings as did Volvo. That was when Volvo had the 600 hp packages back in 97 or 98? There was maybe 40 hp difference between good and bad and that was only looking at hp 500's up to 5200 rpm or so. There would have been a bigger difference yet if they would have looked at applications in a higher rpm range. Eickert's website had some of the data and Hot Boats did a couple comparisons. What I found interesting was when you looked at some of the IR 4 into 1 configs due to the large difference in their runner length, they really didn't do all that well.
(Post 2721959)
Heck, I think that Kennyo's motor was reverting pretty bad at 800hp or so with standard Lightnings.
Originally Posted by bob
(Post 2722125)
The runners are ( i think 22" long ) and have all the same volume. |
1 Attachment(s)
I know of a lot of big power boats running wet exhaust. I even run downturns on my 1400's CMI headers are the way to go. Manifolds are for cars.
(Post 2718988)
Originally Posted by boss27
(Post 2722551)
Can anyone tell what is a CMI Elbow Split Top?
| All times are GMT -5. The time now is 04:27 AM. |
