Polishing & Balancing Props >
Old 10-22-2008 | 11:43 AM
Question Polishing & Balancing Props
I have read that polishing and balancing stainless props can improve performance. I have a 496 Mag, Bravo III with satin finished props. I like to get them polished and balanced. Will I see any speed improvement?
monkey62803 is offline
Old 10-22-2008 | 11:52 AM
Never Enuff
Maybe a little--but not much. Balancing them will help prevent any vibration you might have. I had mine done and IMO it was worth the money.
Jay
never enuff is offline
Old 10-22-2008 | 12:04 PM
Satin finish is faster by a very tiny(.2 mph or so) amount. Balancing may pick up some performance if they are out of spec by much.
Griff is offline
Old 10-22-2008 | 01:54 PM
Knot 4 Me's Avatar
My 260 Chap has a 496 MAG and a Bravo III. Bravo III props are notoriously out of balance from the factory. I sent mine to Brett at Bblades and had him balance them, polish them (for looks and ease of cleaning), and verify/true the pitch across all the blades. He also ever so slightly worked each blade edge. My cruise RPM dropped slightly and I picked up 50 RPM on the top end (which I needed) and 1 MPH at WOT. My goals were to make sure the props were properly balanced, make them look better, not lose efficiency at cruise, and gain a few RPM at WOT. Brett nailed my requests exactly. The extra MPH at WOT was just a bonus.
Knot 4 Me is offline
Old 10-22-2008 | 07:54 PM
Thanks for the Info! My boat is a Chap 256. Can you give me more info. on the place that did yours?
Old 10-22-2008 | 10:06 PM
axapowell's Avatar
Where To
Brett Anderson at BBlades. Does all of my prop work as well!!
BBlades
Dave
axapowell is offline
Old 10-23-2008 | 08:02 AM
Wahoo ATV's Avatar
Racer
You are absolutely correct, Brett and BBlades are the place to go!
Wahoo ATV is offline
Old 10-23-2008 | 08:19 AM
I don't know if the outcome would be the same as on a BB or SB but with my previous boat which had a 300x on it, I picked up 300 rpm after having the prop balanced.
It was a custom prop so maybe it was just so off to begin with. Nevertheless, I've bought brand new, non labbed finished props from Merc that needed balancing almost everytime.
86 apache 22 is offline
Old 10-26-2008 | 09:04 AM
got in touch with Brett. I think I'll give it a shot! Heck, it's cheap to gain an additional 2 mph at WOT!! Improved acceleration will be great too!
tony stamis
Swap Shop
2
07-14-2008 09:12 PM
BAJA WILL
05-05-2006 04:50 PM
fishead
Prop Talk
3
07-18-2005 11:26 AM
MESABALANCING
07-13-2004 02:49 PM
Water Fountain
Fountain
4
01-18-2002 08:16 PM
