building a 454 >
building a 454
building a 454
Old 10-22-2008 | 03:25 PM
Default building a 454
would like to build a strong 454 it is a mag dont care if efi stays on or not. would like
intake
carb
heads
cam
headers
the bottom end is good now so i dont want to touch that this winter would like to see 600hp? or close? is this even possible?
please dont recomend a 540 or some thing bigger as i can not do that at this time! price range of $6-8000 any help,thoughts, ect would be great!
boss27 is offline
Old 10-22-2008 | 03:47 PM
jayhawk261's Avatar
600 hp out of a 454 will be tough without going to high compression. If it is a stock mag now, it probably has 8.8:1 compression. With the components you listed above (the right ones), and your stock compression, you would probably be limited to the 500 - 550 hp range max.
All of the items you listed will run about $6k - $7k total just for the parts. The headers are pretty expensive as I'm sure you know, and a good set of heads with springs and valves will run about $2500.
On top of the parts cost, you'll have some money in R&R unless you have the ability to do it yourself. I don't know if you can do a cam change in the boat. I know in mine, I thought I could because the vertical part of the back seat lifts with the engine hatch. Upon closer inspection, the engine sits low enough that the cam is still below the opening and wouldn't be able to be removed in the boat. Just some things to think about.
We went through my 454 MAG MPI last year and got 501 hp with raising the compression to 9.5:1 and doing basically what you've talked about here. I kept the fuel injection, which will be leaving soon. I'm switching to a carb because the stock manifold is too restrictive.
jayhawk261 is offline
Old 10-22-2008 | 05:29 PM
I agree with jay there.....thats a far reach without a blower and keeping the compression in the real world area, also to run that much cam going to be a issue..just don't see it working well...Rob
ezstriper is offline
Old 10-22-2008 | 05:59 PM
thanks for the imput guys, i think i might be better off with a pro charger....but i am not sure of ecm re-flash, herd lots of bad stories on re-flashes that simply did not work!....just ask jasonsmith on this!
boss27 is offline
Old 10-23-2008 | 05:07 PM
blue thunder's Avatar
I agree going forced induction is your best and cheapest option. Install good exhaust valves, cometic head gaskets and run carbs not injection. That's what I would do. I never dynoed my engines but believe I am close to 600hp with 454s and 177s.
blue thunder is offline
Old 10-23-2008 | 05:21 PM
I have a ProCharged and modified 454 Mag FI. I can give you some input if you would like. I have a set of heads that are built and ready to bolt on 1.94 2025 Iconel valves, etc. $1000. I opted for Edelbrock Aluninum this time, I'm not sure they were worth the investment we saw some gain and of course the weight thing but not enough for the investment. As far as the Cometics I am torn after 250 hours I did have a failure O-ringed this time. I had Tyler Crocket dyno and reflash. I would not do it without being on a dyno again. I ran good for 250 hours but the dyno tune made a huge differance. 720 HP 727 ft lbs and turn key every time. 1998 Velocity 280 with a B-max 1.30 ratio 97.8 MPH GPS.
Bob
RBeyer is offline
Old 10-23-2008 | 07:05 PM
Smile
rbeyer that is a heck of a top speed! what fuel system did you use? headers? cam?.....here's what i think i am going to do.for this winter headers@ a pro charger. this should put me around 620hp!.....again thanks for all the imput!
boss27 is offline
Old 10-23-2008 | 09:53 PM
I just put this one together from spare parts.. 8.7-1 comp,
Edelbrock RPM Oval ports, stock 525SC cam, Used 177 from 525SC, 4.75 - 5lbs boost, CMI E tops from 500EFI. Not bad power for a pretty cheap top end package..
HaxbySpeed is offline
Old 10-24-2008 | 06:03 PM
My apologies typo 87.8 GPS Aeromotive fuels system, 60 lb injectors custom fit to the rail and intake by Tyler, EMI Thunder exhaust, Procharger M3SC, It is a custom grind cam I can get you the specs. I have a perfect Crower custom grind and those heads I spoke of for sale. If you Procharge I would at least look at those items and would Dyno. Speeking from my lessons. Also you probably want to consider a drive upgrade. It is the week link.
RBeyer is offline
Old 10-25-2008 | 08:17 AM
I know you dont want to hear about a larger engine, but I just sent out a deposit to Bill Lawson at Ateco. He is building me 540 form pan to manifold for $8995.00 Comes with a 2 year warranty and he will put it on the dyno after we reuse my Ignition, Carbs Pumps etc.. and make sure it is making 600 HP
995.00 is not to much more of a stretch for some peace of mind.
IMHO
Also he has been great about answering all my newbie go go fast boat questions and is seems to be happy to spend enough time on the phone with you to make you feel comfortable about working with him.
the vig is offline
heater63
Activator
6
04-13-2008 07:44 PM
cliff3466
1
03-09-2008 08:10 AM
teamsynergy
0
05-24-2007 06:20 AM
onesickpantera
Pantera
0
03-05-2006 12:49 PM
dean51267
8
01-15-2006 11:57 AM
