Jesel belt drive installation >
Old 10-25-2008 | 08:26 AM
Vinny P's Avatar
I hate the winter!!
Default Jesel belt drive installation
After my recent issues with destroying a timing gear set, I decided to go with a Jesel Belt drive. I have to say, the kit fit perfectly and was a breeze to install. The problem is, my circulator water pump hits the belt. Before you say go with a cross over, I cant, I run closed cooling. I need 1/2" additional clearance, easy enough to do with either a 1/2" spacer or the long style water pump. BUT, what the hell do I do for my stock Merc serpentine pulley? I looked around at pulley manufacturers and found nothing that would work. I happen to have a pulley from a 575 SC ( thats not mine ) it has a 1 1/2" offset from my pulley. That would work with either a 1 1/2" spacer, or the long style wate pump but Merc gets over $200 for that pulley. Anyone have of a better solution?
Vinny P is offline
Old 10-25-2008 | 09:28 AM
Cant you mashine a spacer for the pulley you have and space out everything 1/2 inch ?
SS 1/2 inch round and drill it so it fits between the crank and pulley ????
DareDevil is offline
Old 10-25-2008 | 10:40 AM
Use the 575 pully......so what if it's not yours..... oh wait nevermind....... lol.......
Here's Johnny is offline
Old 10-25-2008 | 10:56 AM
Vinny P's Avatar
I hate the winter!!
Yeah... They're yours. Maybe you wont notice one missing?
Vinny P is offline
Old 10-25-2008 | 10:59 AM
At least not until May.......lol....... call me in the office when you get a chance.....
Old 10-25-2008 | 11:06 AM
Velocity Vector's Avatar
Crazy Energy
Your pully fell off and rolled under that table over there and I can't find it anywhere. Damndess thing I ever saw. Oh here it is, how in the heck did it get get 1 1/2" narrower in that short off a roll. Sh!t happens I guess?
Velocity Vector is offline
Old 10-25-2008 | 12:03 PM
I need 1/2" additional clearance, Anyone have of a better solution?
I ran into the same problem. Solved it. Question: What block do you have? GM Dart Merlin other? Do I assume that you have a Hyd roller cam?
ROTAX454 is offline
Old 10-25-2008 | 02:30 PM
Vinny P's Avatar
I hate the winter!!
I have a Dart Big M , running a solid roller cam. Any help would be great.
Vinny P is offline
Old 10-25-2008 | 03:43 PM
Somebody probably has a take off one from an upgrade to a crossover system and more hp.
Griff is offline
Old 10-25-2008 | 08:14 PM
Mr Gadgets's Avatar
Charter Member #601
Vinny, Is there room to move the pulley back 1/2", or will it hit. Say you find a pulley that is 1/2" deeper, or you use the 2" deeper pulley that John loaned you, and you put a 1 1/2" spacer in the pulley, Will the pulley rub on the body of the water pump?? Just a thought.
Dick
Mr Gadgets is offline
