Cam and Lifters >
Cam and Lifters
Cam and Lifters
Old 11-01-2008 | 07:45 PM
With your exhaust, I would use the 525 efi cam on the 114. It will have a smoother idle and less chance of reversion.
Griff is offline
Old 11-01-2008 | 08:02 PM
So is the part number the 741 with 114 lobe sep? Thanks griff i just found one of your post that said the 525 cam is the 741 with 114 lobe sep. So what lifters should i use and should i get a cam button? Also recommendations on a timing chain? Griff i do appreciate your help thanks bud!
ubet28 is offline
Old 11-01-2008 | 11:57 PM
I think you will have to order the 741 on a 114 as a "custom grind" although Crane should have it readily available. There is no publicly available part/grind number that I'm aware of. You need to use a cam button unless you have a Gen VI engine. I'm assuming yours is Gen V with a stamped steel timing cover. When I upgraded my 525SC with a retrofit roller cam, I used all the crane parts that Crane had listed as compatible for the application, including the valve springs, lifters, and timing chain.
If I was going to order anything besides an off the shelf cam, I would probably just contact rmbuilder/Bob. He has some stuff that is definately better than Crane's. The Morel lifters are supposed to be much better than Crane's. He should be able to put together a complete package for you.
Griff is offline
Old 11-30-2008 | 10:55 AM
I went with the 741 on the 112. Would i benefit from changing the pistons? If so what piston would work best for me?
ubet28 is offline
Old 11-30-2008 | 03:18 PM
skaterboy's Avatar
If you are interested, I have a pair ( for two engines) of 525EFI's cams, lifters, sprockets w/chains that have 70 hours on them.
Ray
skaterboy is offline
Old 11-30-2008 | 03:31 PM
how much for one cam and set of lifters?
searaycer is offline
Old 11-30-2008 | 04:35 PM
i may be interested in one set also [email protected]
dennis r is offline
Old 11-30-2008 | 07:24 PM
[email protected]
Old 12-01-2008 | 06:48 AM
while we are on the cam thing..was thinking about doing mine as well, have a 509 9.5-1 comp, stock rect port gm heads and alum intake, full stainless marine headers and is a gen VI, thanks guys....Rob
ezstriper is offline
Old 12-01-2008 | 07:22 AM
I'm running the emi short stainless steel risers and my cam is a ultradyne bullet racing cam roller with stock lifters dur @ .50 is 228/236 with a .601 int/exh lift . I have no problem with reverision.
Rockfish71 is offline
