I seem to have a leak coming thru the transom where it looks like the tiller arm comes through. Anyone ever had to replace this? I'm told that Merc sells a kit where you have to dtill into the drive to repair it? Any help would be appreciated.
Originally Posted by johnny b good
(Post 2737561)
I borrowed an automotive bearing puller from Murrays discount auto stores. They dont charge anything to use it, as long as you bring it back. The tool worked ok, probably not as good as the merc. tool, but it did the job for me.
Originally Posted by Revd Up
(Post 2738352)
What did you use to install the new bearing and seal?
Rev'd Up.
Here is a post I made a few months back about my process. There might be some helpful things in there for you regarding the Gimbal Bearing and it's orientation, specifically Post #3. http://www.offshoreonly.com/forums/d...questions.html
Originally Posted by splashandburn
(Post 2737987)
Here is the website: http://www.jrmarine.com/ I have never spoken with him but EVERYONE says he is the nicest guy and nothing other than a powerboat fan interested in helping other powerboaters. His kit is available off the website, otherwise you have to pull the engines. I am most likely just going to pull my Engines to do the job..... |
(Post 2737987)
The swivel seal is a common one to go, The pin is stainless and cleans right up. I have one at the shop that needs to be done as well as the bushing. Merc does sell a kit , but now you are just adding holes for more water to potentially come in at. Best just to pull the engine and do it right. If you have ext. boxes you can do it with out pulling the engine.
I have used merc's kit and I have used JR 's kit both do work very well when ALL the work is done very neatly. The merc kit has two plastic pipe plugs that are on each side of the upper transom plate housing.You have to drill and tap these holes I think it was a 1/2 inch pipe tap, Which drilling and tapping can be easily misaligned and not an easy job for a first timer. The JR kit gives you good instructions,quality hardware. The only thing that I change on the kit is the fine thread socket head screws, to course thread, Because they are easier to tap into aluminum. You can seal up this area really good and I even put another merc decal over this plate with just the socket heads showing through and most people don't even notice it until you point it out.
1 Attachment(s)
Originally Posted by speedreeder
(Post 2740229)
speedreeder how it going?,thanks for the help when I did mine. |
boatnt, Glad to see everything worked out good for you! IMO I think that the rear plate that JR has is the cleanest and the most straight forward repair that is available!!!
| All times are GMT -5. The time now is 03:38 AM. |
