454 SS Truck engine >
454 SS Truck engine
454 SS Truck engine
Old 11-13-2008 | 06:53 PM
fhb,
One thing to keep in mind is that the hp is "net" horsepower, not the same as flywheel horsepower. That engine probably makes closer to 350 "real" horsepower, its kind of hard for a 454 to make much less than that. You can do a cam swap, but be prepeared to do a lot of work on the heads to accomodate much more than the stock cam. You need to remove the valve rotators and do some machining on the guids.
Other than that, its no different than any other engine ... make it breathe better and it should make some more power. Its only around 8.5 to one compression so there is only so much you can do
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 11-13-2008 | 07:57 PM
Originally Posted by fbh-velocity
Any suggestion how to make 400+ Hp and more tq.?
Smogger heads, bad camshafts, bad blocks............
I have four letters for you.....
F O R D
My friend has one of those SS trucks and it is a turd!(looks nice but that is about it?) My "bone stock" 351 Bronco can outrun it, outpull it and outclimb it! and I don't spend as much in fuel!!!
Stinger390X is offline
Old 11-19-2008 | 04:30 AM
vette131's Avatar
F O R D
i work for ford & you're smoking crack or your friends truck has something very wrong with it!!!
vette131 is offline
Old 11-19-2008 | 09:04 AM
44MTI's Avatar
I found that Edelbrock has #3764 TBI manifold and #2162 cam 218 228 .500 .500. They also have headers and high flow cat. But will the stock TBI (50mm) flow enough air? and how much power will this comb. make?
It looks to me that a mild tuned truck engine is close to marine spec.
I have a 1995 low hours mercruiser 454 magnum EFI/MP 385 propHP How about using this engine? does it pass emissions test etc.? All good advises needed
I believe that is the cam and intake that I used, Along with headers and a new set of dual exhaust. The TB actually worked just fine. You can't believe how much different it was. Everyone needs to get over the HP ratings, It's the torque you fell when you push the pedal, and you will only get that with a big block. Wish I still had it, very fun truck.
44MTI is offline
Old 11-19-2008 | 11:09 AM
F O R D
in fuel!!!
your friend's SS must be loaded down with buckets of gumbo or something...My roomate in college had one and we used it to pull boats around...I've also borrowed other guys broncos with 351s, no way they had more power than the 454 ss...nicer interiors and thats about it.
redstinger is offline
Old 11-19-2008 | 11:24 AM
We used to take those things in on trade when I was in the car business.
That is the engine that they put in the dually that year. Suck gas and make torque in the very low end.
I would agree with most of the advice on this thread all ready, but here is my .02 anyway.
I built a low budget engine for a guy that was mud racing from one of these engines. Threw the entire top end in the trash, Put a 3-6000 solid flat tappet cam. Big oval chevy heads,no special valve work etc. tall single plane intake and 10.5:1 piston in it and it will pick the front end off the ground now. Might be a little more than you want to do, but at the least, get rid of the heads onthat thing.
Good luck. THe good thing is that there is a ton of used parts out there for 454's that can be bought right.
Should be a fun truck when it is finished.
jeff1000man is offline
Old 11-19-2008 | 11:45 AM
Put a whipple kit on it and be done with it. I had a couple of cutomers with that generation of truck and they were a blast.
Nuff said....Mike
Michael Garibay is offline
Old 11-19-2008 | 11:47 AM
These guys have the experience with this application:
http://www.tpis.com/
Call them,
Jeff
hallj is offline
Old 11-20-2008 | 09:01 AM
Default getting it to hook
All very valid advice. I had one back in 1993 and out of the box had the heads ported, a little more cam and fuel delivery re-programming and a K&N box. This all made a huge difference in torque and power but.......The truck just couldn't launch. Ya gotta build a multi link for it or no matter what you do, off the line will make little or no difference with big street tires. If mid-range acceleration is what you are after then that's all fine but chances are that isn't what you are looking for.
Also, although bullet proof, the Turbo 400 3sp killed me on the road. Back then there wasn't a whole lot you could do with the 4 speed automatics to make them strong enough but today is a different story.
On another note; I currently ownd a 454 dually with a wipple charger and it will burn the 4 rear tires until they melt, LoL
86 apache 22 is offline
Old 11-21-2008 | 11:58 PM
articfriends's Avatar
I had a 94 dually with the same motor,it was a turd and drank gas then I bought a full banks exhaust/power kit for it that made night and day difference,without even cracking into the actual motor I got about a 50% hp/tq increase and 20% better mileage. It went from being a slug off the line to smoking the duallys so bad I had to put in a detroit locker,Smitty
articfriends is offline
