Intake manifolds >
Intake manifolds
Intake manifolds
Old 11-28-2008 | 05:36 PM
  #31
Originally Posted by ezstriper
If I'm not mistaken the 950 holley is just a race version of a 750 not actually a 950 cfm carb...
Bingo. Carb numbers, or model numbers for that fact are sometimes misleading. Talk to a carb professional before you jump into the fuel pool heads first.
ROTAX454 is offline
Old 11-28-2008 | 06:51 PM
  #32
Originally Posted by Rockfish71
Carb Sizing formular is:
CARB CFM = Cubic Inches x Max RPM's / 3456 x VE%
VE is Volumetric Efficency. 100% is not likely
A good built motor is around 90%
502 x 5200RPM /3456 =755.32 CFM Carb
755.32 x 90% = 679.79 .
502 x 5600RPM /3456 =813.43 CFM Carb
813.43 x 90% = 732.09
The HP 500 used a 800CFM
Seriously though, I do understand that for general purposes, the VE to CFM sizing does work. My point is that for today's motor with so much really really good performance stuff out there, general terms in many cases just doesn't fit. Example: Look around. Several 496 marine motors builds making max. HP at 6000 RPM are using a 1050 dominator.
496 x 6000RPM / 3456 = 861.11 and that is at 100%. The days of using poor flowing peanut port heads are few. And that is a good thing. We all benefit from the aftermarket desiging and building great performance products.
ROTAX454 is offline
Old 11-28-2008 | 09:33 PM
  #33
SB
Why you crappin' on Rotax ? he makes many valid points.
Here's my quicky opinions:
Holley's cfm recomendation chart is very conservative. This is is so the general public doesn't get themselves into trouble. Yes, it is easier to hurt power/driveability with 'too big' of a carb vs 'too small' but what is too big today with modern cams, heads, and 500cid's ?
Many engines with modern cams, intakes, and heads will have good driveability and very good top end with a carb sized somewhere around 120% with a single plane and around 150% with a dual plane.
Yes, carb #'s are all monkeyed around. The Hp950 is closer to 830cfm. But they work well because it's metering is very good. Not because of big airflow. Why does the HP500's 800cfm carb work well on bigger motors ? It meters fuel well.
If you had a more airflow capable carb and kept the good fuel metering, then bang, the engine would make more power. The trick is to find an off the shelf holley that meters fuel as well or to find a carb tuner to build one for you.
Sometimes, the airflow demand makes a carb not meter so well, but more often than not, a carb that does not meter so well is because the carb metering system suks.
Don't always blame a poor performing carb by saying 'it's too big.'
BTW: as long as there is vacuum measured under the carburetor, it is restricting airflow to the engine. It's almost impossible to make a carb big enough to cause absolute 0" vacuum. A 1250 won't even do that on a 502.
SB is offline
Old 11-29-2008 | 10:09 AM
  #34
Thunderstruck's Avatar
Got out my dyno sheets from my session with 502 ci with custom cam and 305cc AFR heads.
Stock (old) 500HP blue carb with choke and stock dart intake-563 hp at 5400 rpm, peak tq at 590lbft at 4400 rpm.
Switched to Holley 950 cfm Racing with 81 primary jets and 82 secondary jets up from the 79 square-586 hp @ 5400 rpm, peak tq at 605lbft at 4500 rpm.
Switched to Edelbrock Vic Jr. intake with 1" open spacer-595 hp @ 5500 rpm, peak tq 613lbft @ 4600 rpm.
These are corrected numbers, CF was .99 that day.
I think that Wags382 massaged a stock 500HP carb and did well with it by removing the choke along with some additional work.
Edelbrock intakes are also much less expensive than the Dart intakes.
Long time cult member.
Thunderstruck is offline
Old 11-29-2008 | 10:58 AM
  #35
CB-BLR's Avatar
Chris
On my 548, on a dyno, using a massaged Victor manifold, my motor made 12 more ft/lbs of torque at 3000 rpm with a 1050 annular discharge carb, than it did with a 950HP. The 950 laid over and died by 5000 rpm. The 1050 was up over the 950 by 31/hp at 5000.
The motor made 685/tq at 4600, and 682/hp at 5750.
Thankyou Bob Madera aka RMBuilder.
Chris
CB-BLR is offline
Old 11-29-2008 | 03:26 PM
  #36
we kinda got off the post here... how about with stock rect heads and cam ??
ezstriper is offline
Old 11-29-2008 | 06:51 PM
  #37
CB-BLR's Avatar
Chris
Originally Posted by plumb crazy
Witch is better for top speed dual plane or single plane intake manifolds? I have a zz502 502hp and I'm not sure what to put on it.
For all out top end on a 502, I would pick a Victor Jr. It will probably beat the RPM air-gap by 10-12 hp at 5200-5400 rpm. The RPM air-gap will beat it untill about 4500 rpm.
I would use a Holley HP1000 carb, which is just a 850 DP with the choke horn removed and better metering circuts.
Been there... tried all that... on a dyno... with that motor.
Chris
P.S. I would have a cam done by Bob Madera aka RMBuilder. The guy really knows his stuff !
CB-BLR is offline
Old 11-30-2008 | 08:00 AM
  #38
thanks....some good info from this thread....Rob
Mag27
8
04-22-2008 07:41 AM
BillFormula
Wanted
1
03-11-2008 05:56 AM
VelocityMike
05-01-2005 01:02 PM
FloridianSon
2
03-16-2004 10:09 PM
gofastpilot
5
08-26-2002 04:25 PM
