502 oil pump question ??? >
Old 11-24-2008 | 08:06 AM
Default 502 oil pump question ???
I have a 98 502 gen6 built up with about 440 of open valve seat pressure is this oil pump worth using this pump or replacing it and what type of affordable pump is out their ,do I use my old pick up tube . Thanks for any input. Alec
alecsammy is offline
Old 11-24-2008 | 08:22 AM
The stock oil pump is fine make sure you use a new one if possible just change to a arp pump shaft that has the steel ring that go's on the pump side check the new shaft to the old shaft to make sure it is the same lenght... are you talking about the relief pressure oil spring or cylinder head vavle spring pressure?
Rockfish71 is offline
Old 11-24-2008 | 08:33 AM
Use a melling M77-HV with an ARP rod. Melling also makes a replacement pickup for the stock pan. I can get the # in a little while.
Eddie
Young Performance is offline
Old 11-24-2008 | 08:54 AM
Alec if you're using your old pick up make certain it's clean inside consider a new one they are not expensive and you can wash it inspect and use . I like to replace the pump on anything I build it's cheap insurance if you're going to use the pump you have at least replace the drive shaft with a steel coller one from any of the manufacturers IS77e in Melling
MESABALANCING is offline
Old 11-24-2008 | 09:25 AM
It is also good when you are done seting up the pick tube on the oil pump do two small tig welded tacks. tack the pickup to the housing a must if you reuse the pick up tube
Old 11-24-2008 | 07:02 PM
Can I use the stock pick up tube or does someone know the part number for a new pick-up screen Thanks
cloudmaster_321
Do It Yourself, Boating on a Budget
2
05-18-2008 01:59 PM
cloudmaster_321
12
08-08-2007 10:30 AM
Leathl_WS6
9
12-06-2006 02:22 PM
dodsonartic1
2
06-27-2005 09:54 AM
BadDog
5
06-02-2003 11:47 AM
