HEI Distributor Shaft Diameter >
Old 11-25-2008 | 01:10 PM
Default HEI Distributor Shaft Diameter
Does anyone know for sure what the diameter is of the Merc/GM HEI distributor shaft w/ an external coil is?? (2000 502 MPI) I found a few posts here that say its .491". According to a GM parts site (Pace Performance), the small HEI cap w/ ext. coil is .428"
ctuck0659 is offline
Old 11-25-2008 | 03:59 PM
.491 that .428 has to be a misprint...now thats a GM, merc I don't know..Rob
ezstriper is offline
Old 11-25-2008 | 06:53 PM
I'm not so sure it's a mistake- I took off the distributor gear and measured the shaft with the only thing I had handy- a cheap plastic caliper. It's only graduated in 1/16ths and it measured not quite 7/16" in diameter. .428 is just a little over 13/32". . .
Old 11-26-2008 | 01:10 AM
GM made both. The engine you have does have a .428 diameter shaft. Do you need a gear? If so, Scoggins-Dickey is probably your best bet.
Eddie
Young Performance is offline
Old 11-26-2008 | 06:53 AM
damn, never heard or saw that size, and none of the main manufactures makes bronze gears that I see in that dia.
Old 11-26-2008 | 07:47 AM
Rather than use bronze, I ordered hardened steel: it's called a Melonized coating and is indicated for steel billet cams. Summit and Jeg's both sell them although I'm not sure in what sizes. I ordered mine from www.paceperformance.com
Old 11-28-2008 | 11:47 PM
Neither Jegs or Summit carry the gear in .428. I've looked before, since they are so easy to order from. Jim Pace has a great parts dept. to order from.
Old 11-29-2008 | 01:33 AM
I've ordered a few things from Pace as well. Good prices and shipped fast.
Griff is offline
Old 11-30-2008 | 09:37 PM
Crane sells a bronze one too. I believe it's actually .427"
RichardCranium572 is offline
Pismo10
5
07-04-2007 07:01 AM
offthefront
2
07-03-2007 08:24 AM
Mike Paula
0
08-07-2006 08:10 PM
klmken
3
07-01-2005 11:18 AM
cooltoys61
15
08-12-2004 10:13 PM
