More hp out of a 500hp >
Old 12-10-2009 | 03:33 PM
  #41
4195's Avatar
Can You Hear Me Now??
Originally Posted by Young Performance
No, I can't make the show. I will be in Vegas this weekend for a little R and R.
The biggest thing I didn't like was that there aren't any openings in the head that lead to the lifter valley. The only openings are the oil drain holes on the ends of the head. That's another thing, the oil drain holes are way to small. I spent a bunch of time opening the holes and opening a path for the oil to flow out of the head. I run a bunch of oil pressure, so there is a lot of oil going to the top end. I need to get that oil out of there and back into the pan as quick as possible. I open the holes in any set of heads, but none are close to as small and obstructed as the AFR's.
Eddie
Eddie I am running a pair of 500 hp with a roller set up and slightly bigger cam. Engines have stock heads and are suppose to be 550hp. the motors are from Fonz in New Jersey, Do you think I would benefit from Dart Pro 1 heads and if so how much? I am trying to sneak some extra power out. The motors are in my Cig Cafe Racer and with the labbed props I have seen speeds at 78,6-78.9 and would like to get it to 80mph if possible, I am so close I feel i have to at least try.
4195 is offline
Old 12-10-2009 | 05:38 PM
  #42
LV's Avatar
LV
Originally Posted by ubet28
I have a 500hp carbed, i just had the whole thing pulled apart its been honed and cleaned and i bought the 741 cam to put back with new lifters.
I was wondering what would need to be done to 650 to 750 hp out of the motor if i can i see 650 with out blower i would go that route if i have to add blower want 700 to 750.
Also with the blower which is the best candidate for the price and the best one for the motor!blower shop pro charger Whipple what? I am not sure what would be the best route to go. Thanks for looking jeramy
My 500's where pulled out this week, they will be 650's this spring, brodix heads, new rotating assembly, new everything, hydrolic 555CID's by Smith Power, cant wait!
LV is offline
Old 12-10-2009 | 10:36 PM
  #43
They will absolutely benefit from the aluminum heads as long as you increase the compression. They will benefit a little from it being just a better all around head, but the biggest gains will come from the compression increase. It all depends on what was done to the engines. Are the bottom ends completely stock or have they been rebuilt? If they are stock, you will have a hard time getting all of the compression that you can because the piston is so far in the hole. You would have to get the smallest combustion chamber you could and run a thin head gasket....like a .027 from Cometic.
In order to get to 80, you would only need about 30 more hp. That's easy. With a good set of heads, you should be able to break 600 without a sweat. Let me know if I can help.
Eddie
Young Performance is offline
Old 03-13-2010 | 02:33 PM
  #44
Dean Ferry's Avatar
Veteran: Air Force
Well,
i started collecting my parts today for HP500 upgrade project, with a purchase of 2 sets of new KE headers
Everything is for sale @ a certain $$
Dean Ferry is offline
Croozin2
6
09-24-2007 05:29 PM
BLOWN85
Velocity
0
09-13-2007 11:04 PM
BLOWN85
Velocity
0
09-09-2007 09:42 PM
sleek1
8
09-01-2007 05:18 AM
thedonz
01-04-2004 11:55 PM
