CMI headers
Old 12-10-2008 | 11:07 PM
SC'd engines do not need as good of exhaust as N/A engines. The SC will compensate.
Griff is offline
Old 12-10-2008 | 11:30 PM
That is true. THey always have a littel higher head pressure, but you have to be carful lso if they are not making boost at low rpm's, or if you pull out of the sticks real hard whrn they go airborn.
It's all about the design, but there is nothing wrong with those manifolds. I never said that there was.
jeff1000man is offline
Old 12-11-2008 | 02:29 PM
I am talking about a 500hp.
Thanks Guys for the replies i was not trying to say they EMI stuff was junk. I would not of bought it if i thought that. I was just wondering if the 2800 for the cmi's would be worth the cost. As for the HP i was considering buying a 250 blower from the blower shop to put on to get me to 600hp.
Would i be better off using the stock heads or changing them? Would i need to run a chiller?
Say 250 blower and stock heads what kind of power running 6#'s of boost with the 741 cam?
Say 250 blower and brodix or afr heads what kind of power running 6#'s of boost with the 741 cam?
If anybody has suggestions,by all means please speak up! What i want is 80 mph in a 25 ft outlaw 1998
ubet28 is offline
Old 12-11-2008 | 02:47 PM
You should make at least 650hp with the stock heads and the 741 cam and a 250 blower at 6#.
Griff is offline
Old 12-11-2008 | 05:13 PM
AIR TIME's Avatar
if you put a 3'' imco box which is in the swap section and you have 500hp with a 28pb1 prop you should hit 80mph. and its 900 bucks
AIR TIME is offline
Old 12-11-2008 | 09:03 PM
Where is the best price on one and will it help my drive out with the blower. as far as reliability help me or hurt me i would like my B-1 to last this season before i upgrade next winter
ubet28 is offline
Old 12-12-2008 | 01:45 AM
The used imco box is listed in the classifieds. It won't do anything for relaibility or helping the drive survive.
Griff is offline
Old 12-12-2008 | 08:01 AM
I am not sure what kind of boat that you have but some boats like a box and some don't. I have a 3 inch rise IMCO box on my boat and a 2 inch short IMCO lower. I have a friend that has the same power and has a stock X with a standard IMCO lower and he is as fast as me! Another thing to think about is what kind of steering do you have. If you already have dual ram hydraulic you will need to add wing plates to the box. If you don't have dual ram hydraulic you will need to get it if you go with a box. Either way you are looking at more than the price of the box. You will also have to pull your engine to install the box and you will have to raise your engine 3 inches to use the IMCO box. These are all things to think about.
I would say for what a set of CMI E Tops are going to cost you could get a procharger M-3 kit and go way faster than anything else you could do for the money and trouble. The EMIs will be fine with a stock procharger kit.
502stang is offline
Old 12-12-2008 | 11:18 AM
I would say for what a set of CMI E Tops are going to cost you could get a pro charger M-3 kit and go way faster than anything else you could do for the money and trouble. The EMIs will be fine with a stock procharger kit.
The boat is a 1998 25 outlaw.
Ok thanks, i have just purchased a hydro add on kit in the summer i could always up grade it to full hydro if that was the case. Also the motor is already out of the boat.
The thing with the procharger i just really dont like the way they look. Is the m-3 better than the 250 blower from the blower shop?
I am up for what ever is the best way to go.
ubet28 is offline
Old 12-17-2008 | 12:36 PM
AIR TIME's Avatar
there was a stock 525hp 25 ol he put the 3''box and hit 81gps know he went to a merc 600 and 2'' shortie plus 1'' spacer he was working on the speeds of 87 plus. me I have a 2'' shortie 670hp got 83gps but ran out of prop my new motor is a DEAN GELLNER 1000 ABOUT 1050HP OR SO WE WILL FIND OUT SOON.I ran a stock b1 drive from 95 to 06 with out any troubles. new drive will be a b1x shortie. mine boat is a 24ol should break 100 plus.
AIR TIME is offline
