Bow Lift..prop rotation >
Old 12-25-2008 | 03:40 AM
Default Bow Lift..prop rotation
What is the correct direction of prop rotation to get the most bow lift on counter rotating drives and is it the same for V hulls and Cats?
Will more bow lift cause quicker wear of the drives or steering on heavier boats (7 to 8 thousand pound )
schiada.cat is offline
Old 12-25-2008 | 08:06 AM
blue thunder's Avatar
I got more bow lift on a straight vee spinning in.
BT
blue thunder is offline
Old 12-25-2008 | 09:31 AM
all FOUNTAINS spin inward more lift (sonics)out ward less lift helps with chimewalk
acaruso is offline
Old 12-25-2008 | 01:28 PM
does inward mean from the top of the prop .. the starboard spins counterclockwise and the port clockwise?
Old 12-25-2008 | 01:58 PM
YEP !!!!!!!
DareDevil is offline
Old 12-25-2008 | 03:36 PM
H2Xmark's Avatar
it is different on a cat, depends on where the drive is mounted , either closer to the tunnel or closer to the outer hull
will perform different on prop rotation
H2Xmark is offline
Old 12-27-2008 | 09:16 PM
HotPursuit's Avatar
Turning in always seems to give more bow lift.., rake will make a big difference 2..
HotPursuit is offline
Old 12-27-2008 | 09:27 PM
I always thought turning in lifts the A$$ and out lifts the bow ?!
But i quess i'm wrong.
But if you think about it it would make more sence,,,but then again what makes sence on a boat ? LOL
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
Freeryd
5
05-15-2008 06:32 PM
Pure Energy
Prop Talk
3
07-19-2006 07:35 PM
OffDuty
11
05-26-2004 07:34 PM
BadDog
5
11-01-2002 07:31 AM
