-   -   496 upgrade (https://www.offshoreonly.com/forums/general-q/200991-496-upgrade.html)
Jeff P31 01-04-2009 01:56 PM
496 upgrade
Looking to upgrade a 496 mag to 496 ho . what all will have to be changed ? And what about the computer ? thanks for any help Jeff
indywhsle 01-04-2009 02:20 PM
How much are you ready to spend? I myself that it is worth the money just to pick up 30 hp. If you are going to upgrade spend the money and you can go to 700hp for about 10-15 grand. Just my opinion.:drink:
GO4BROKE 01-04-2009 03:17 PM
I think its just a cam and computer upgrade.
LAKESIDE RESTORATIONS 01-05-2009 08:05 AM
There are several different upgrades. Some are better than others for the money. The 2 biggest & best power makers are the Raylar kits & the whipple kits. They are also the most money. However there are lesser costly things that can also be done to increase perf & power, but again some are better than others there.. We have done quite a bit of work with 496s. It would be more helpful if you could let us know what kind of power you seek & ammount you are looking to spend.. :) Then we can let you know what would give you the most for your $$ :) Jamie / Lakeside
Baja_man 01-05-2009 10:16 AM
I too think it is just a cam difference between a 496 mag and 496 HO. Also in some of the older models the Ho had forged internals.
LAKESIDE RESTORATIONS 01-05-2009 10:30 AM
Some of the 496's did have forged parts. Also the main difference between the mag & mag Ho is the mag Ho has a different cam AND ecm program. Jamie / Lakeside
Griff 01-05-2009 12:29 PM
You would be $$$ and HP ahead to go with a Raylar Kit.
Jeff P31 01-05-2009 04:37 PM
We inquired a 496 mag from a wreck ,and have it apart . And thought while it was apart that if it was just a cam change and a computer fix for the extra hp we would change them . we are not looking to put a raylar kit in it . One 750 x 2 hp boat is lots . thanks again for the help Jeff :ernaehrung004:
TylerCrockett 01-06-2009 06:42 AM
It is a camshaft and a ecu program. I might have a used take out cam.
Jeff P31 01-06-2009 09:02 AM
Can the current ecu be reprogramed or do i need to get a new one ? If so how much ? thanks again Jeff
bobl 01-06-2009 10:54 AM
Send it to Whipple. He can put a stage 1 program in and you'll get a little more power than a stock HO. No one else can do it.
KEPP 01-06-2009 11:30 AM
Besides cam, ecu and supercharger kits you could also start with a simple flame arrestor upgrade and even a exhaust system upgrade to increase power. Hardin Marine makes a nice 496 billet flame arrestor with increased surface area and Lightning as well as Hardin makes a great header system for those motors. Like everyone has mentioned it really depends on how much you want to spend on the project. ;)
Jeff P31 01-06-2009 01:05 PM
Just like to say thanks again for all the help Jeff :ernaehrung004:
