hp600sci to hp700sci conversion >
Old 01-04-2009 | 05:05 PM
Default hp600sci to hp700sci conversion
I have a pair of 600sci's ...what can I (easily) do to get more from them? Changing the pulley doesn't work...Does someone local make a chip to allow the computer to allow more boost? I'm in Sarasota Fl. Thanks, Michael.
nevadagame is offline
Old 01-04-2009 | 05:49 PM
CB-BLR's Avatar
Chris
The reason that changing just the pulley doesn't work is because of the computer controlled boost bypass, that bleeds off pressure in order to limit the hp of the engine.
Talk to Dustin Whipple.... the designer of our superchargers. Ph# 559-442-1261
ECM re-program = 675hp
ECM re-program +re-routing of innercooler water + 700 pulley = aprox 750+ hp
Downside is that you have to run 91 octane fuel.
Most hp per dollar you will find.
Chris
CB-BLR is offline
ironfist
Great Lakes and Canada
3
04-01-2007 06:41 PM
MAGIC525
05-04-2006 08:16 AM
Doller Offshore
04-22-2006 07:20 PM
mcraymond3
0
06-07-2004 02:59 PM
Michael Garibay
8
11-19-2002 10:17 AM
