James yancey in wareham ma [email protected] sold this motors to me and i can say dont buy from him, he disapeard when i payed him the deposit and did not answer phone calls, and when he finally did, i set upp arrangement for pick up and payed the motors in full i fought everything was ok.
And when i finally got the motors to me in sweden and saw that the computers was missing i tried to callhim and e-mail him but no answers it STINKS Erik |
Check with Mark at Precision Marine in Louisiana, or Tom at Flagship Marine Engines in Punta Gorda , Florida USA. They can probably supply you two MEFI4B ecms with a proper program that will run you 375HP Volvo GI engines.
These Mefi4B ECMs will be the only ecm's that will plug into your harnesses on the engines and operate correctly without changing the entire engine harnesses, which would be an very costly change. Hope you get your ecms fairly easily and solve your dilema quickly. Sorry for your misfortune with this seller. Most us us here in the Marine Performance industry and OSO are standup companies and individuals and would not treat you this way. Good Luck! Best Regards, Ray @ Raylar |
Thanks for all your help, i will try to call them
Erik |
You might want to post here. This area helps warn others and will call out the other party sometimes.
http://www.offshoreonly.com/forums/beware-stolen-183/ |
Here comes one link to the guy who screwed me up on the ecu:s, he has done the same to other people as you can se..
Dont do business with him http://boston.citysearch.com/profile/43795296/ |
I can have those ecu's in about 3 days. new OEM program for your specific (by serial #) engine.
| All times are GMT -5. The time now is 11:36 PM. |
