Originally Posted by Baja_man
(Post 2792317)
I would think with 800HP it would not have an issue. Here is a link to a 32' Sunsation making 875HP and it seems to fly with only one motor where two is the norm.
http://www.offshoreonly.com/classifi...o26115-en.html |
Originally Posted by rssteiny
(Post 2792369)
Did they even make a 32 baja with single engine ???
I dont think they did but anything could be modified. |
Originally Posted by chris-jack
(Post 2792196)
i try to compare the power of my boat (Baja 32 with 2 x stock 454 mags) with others with just one engine. mine have a little more than 700 hp and total weight of ~6000 lbs.
A 32 Baja with twin 454's weighs a lot more than 6000#. Its closer to 8000#. In boats that can be equipped with either a single or twins, a single with 800 hp will run faster than 2 400hp engines. Using a 28 Pantera as an example. Twin 502/415hp run about 80mph. A single 700hp will put the boat over 80mph. The single will break drives a lot easier. |
| All times are GMT -5. The time now is 09:58 AM. |
