how much hp make sense in a 32ībaja? >
how much hp make sense in a 32?baja?
Old 02-07-2009 | 08:21 AM
  #41
Originally Posted by JaayTeee
It starts to chine walk, then it heels over
and stays there.
It's like being banked over like you're in a turn,
but you're going straight.
a bad joke???
chris-jack is offline
Old 02-08-2009 | 07:49 AM
  #42
Wohin findet man Österreich ausführen Sie eingeschaltet?
Baja_man is offline
Old 02-08-2009 | 11:54 AM
  #43
Full Force's Avatar
Originally Posted by Baja_man
Flege on here has a 32 with HP500 in it, he might chime in and give you what he thinks.
Flegs is the same hull I have, same as the taller deck 320 88-89 years not the ES, it was a totally different animal. The one in the video is also a Force/Caliber hull
Full Force is offline
Old 02-08-2009 | 11:57 AM
  #44
Originally Posted by chris-jack
do other boats not have this pad? the flat spot on this boat is only 6 or 7 inches wide and 5 ft long.
Some boats have pads, but most do not. Velocity's use a pad with great results.
Griff is offline
Old 02-08-2009 | 12:37 PM
  #45
bad translation program
cannot find sense in this sentence, sorry
Old 02-08-2009 | 12:38 PM
  #46
Originally Posted by daredevil
Take it to a fiberglasser,,or fly mine over to you and have him or anybody u know glass a Thru -V- over the Pat on the botom.
All issuis resolved !!!!
Or make the botom strakes wider !
I even know a guy in germany that could do that for ya ,,,may even be better then buyng engines and little less expensive.
His name is Carl Class in Worms Germany owner of Classperformance boats.
Tell him a german guy from USA send u.
my pad is just 6 inch wide!!! i will call carl imn worms tomorrow!
Old 02-08-2009 | 01:04 PM
  #47
Originally Posted by AIR TIME
VERY TRUE after the 500s check your prop shaft height if it 6 to 7 1/2 '' from theedge of the hull there deep/ in a single you would measure from the pad. so if your twin is deep go for a set of 1 to 2'' shorties it helped my ol out a lot.
i would like to post a picture, but have no idea, how!!!
Old 02-09-2009 | 10:16 AM
  #48
Originally Posted by Griff
The pad is the flat spot at the rear bottom of the hull. Pads are there to help increase speed. When you get up to speed, the pad will be about the only part of the boat touching the water.
I think you are worrying more about making changes to the boat before you're even comfortable with it. How much seat time do you have in the boat????
Get comfortable with it with the power it has and you will learn what it will need when you want more speed.
and stays there.
I like to send or post a picture of the bottom of my boat, photografed from the back to somebody who knows about the problem.
Old 02-09-2009 | 10:41 AM
  #49
JasonSmith's Avatar
There is nothing wrong with the 320es. It is a great boat. You just need to have k-plane tabs & outward rotating propellers to keep it stable.
You can put 600hp a side in it & be just fine.
If you are thinking there is a problem with the bottom, you are just mistaken. The bottom of that boat has a pad on it. Think of a "v" & take the point off the bottom & replace it with a straight line. That is what the bottom of the boat looks like. Lots of boats have a pad.
It won't be an issue if you put on the k-planes & turn the propellers outward.
JasonSmith is offline
Old 02-09-2009 | 12:00 PM
  #50
It is not a "problem"
It is just the way it is. Its a Baja 320ES. Its not a Cig Top Gun. It may not be the best design, but it will be fine. There is no reason to throw money at it and do major changes to the bottom.
Griff is offline
