-   -   Nordic Heat - 600sci motor upgrade (https://www.offshoreonly.com/forums/general-q/202867-nordic-heat-600sci-motor-upgrade.html)
CB-BLR 02-21-2009 10:57 AM
Originally Posted by MarkDonzi (Post 2805229)
Chris,
those are awesome results! What are you using for drives Bravo XR's? Good Luck!
Mark
Mark,
The boat has an IMCO Extreme SC outdrive on it.
Chris
CB-BLR 02-21-2009 11:06 AM
Originally Posted by redbud35 (Post 2805352)
Cool deal.
I'm surprised your boat wasn't faster to start with.
The boat was actually the fastest in the stock 600sci configuration with a Hering 26 pitch, 5 blade Bravo style prop, at 83.8 mph. This was bouncing off the rev limiter.
The reason I choose to not use this prop was because of the extremely low slip percentage of 5.5%. That and it would overshoot my target RPM of 5800. I was worried that 750+ horsepower thru Bravo XR gears (IMCO SC outdrive), along with the low slip numbers, would break my drive.
The 90.4 speed was done with a Hering 27 pitch at 5600 which is aproxomately 5% slip. I am going to take the 1.5 inch spacer out of my drive and see if I can get the slip number up, along with reducing the chine walk that starts at about 88mph.
Chris
Raylar 02-22-2009 03:03 PM
Good Job!
CB-BLR very nice results! Looks like Dustin "DustoCharger" as I call him! has the great way to get a 600sci up to that 700HP plus range! Nothing like a little more boost!
Keep an eye on your valve train as that's probably going to be the system that will need careful scheduled maintenance.
Best Regards,
Ray @ Raylar
Steve Zuckerman 02-22-2009 03:20 PM
Hi Chris,
That's a very nice number for a modified "stock" motor. Congratulations,
Steve
CB-BLR 02-23-2009 02:25 PM
Thanks guys,
I really appreciate your input.
Chris
