Any experience with Skeggards... >
Old 02-08-2009 | 03:37 PM
Default Any experience with Skeggards...
has anyone used them? What do you think?
I do not like the idea of drilling holes in the skeg, but I was thinking that if the whole skeg is still intact, then I could fill the skeggard with epoxy and forget the bolts.
Thoughts?
Scott
GSELITE2000 is offline
Old 02-08-2009 | 03:51 PM
CB-BLR's Avatar
Chris
I have used them on several boats, and they seem to work really well. The special bolts are round headed so as to not produce much drag. The Skegaurd looks pretty good also.
Chris
CB-BLR is offline
Old 02-10-2009 | 06:54 AM
Thunderstruck's Avatar
I used one on a mildly torn up skeg. Worked well. I like the epoxy idea. My skeg had a lot of corrosion under the Skeggard when I finally took it off.
Tom
Long time cult member.
Thunderstruck is offline
Old 02-10-2009 | 11:42 PM
Default Skeggards
I have Skeggards on my drives. The one concern I had was water that stays traped in the gard. Besides corrosion, I was concerned with the water freezing (I live where that can happen) and causing damage. I drilled a small drain hole in the bottom of each and just check to be sure all water drains out before I put it away. The epoxy idea would solve this problem and should work fine.
blefever is offline
Old 02-11-2009 | 12:35 AM
My opinion, the skeg is sacraficial and its supposed to break off with an impact. It breaking off may keep more damage from occurring.
Griff is offline
cauzmik
Sunsation
2
07-29-2008 05:58 PM
TC
05-01-2005 09:32 AM
