convert 454 to 525sc >
Old 03-01-2009 | 08:38 AM
  #41
heres a complete new setup, 482ci, std 454 bore, 4 bolt, eagle crank and rods, KB forged blower pistons, comp blower cam, milodon 10qt offshore pan, weiand 177 with 4-5 and 6-7 psi pulleys, 7500 obo, Rob
ezstriper is offline
Old 03-01-2009 | 09:50 AM
  #42
does a blower help to rise hp more at midrange or at high rpm´s? my intend is to have the horses at medium rpm´s. is than this conversion the right thing?
chris
chris-jack is offline
Old 03-01-2009 | 02:41 PM
  #43
both, these blowers start making boost as soon as you start coming on plane so boost in H/P comes thru the midrange as well as full throttle...
Old 03-01-2009 | 05:20 PM
  #44
You don't need actual hp in the mid range. You need torque. Roots blowers, like the 177 make lots of torque in the mid range.
Griff is offline
Old 03-02-2009 | 09:47 AM
  #45
thanks griff, thats what i want to hear. :erna ehrung004:
how much will the blower increase my fuel consumption? I think/fear in the end it will be very thirsty?
Old 03-02-2009 | 09:57 AM
  #46
It will use the fuel that a 550 HP engine should use.
Don't forget that if you get interested, I have all these parts on my shelf that I would like to sell.
I am in the middle of buying parts for my personal boat, so whenever I sell something, I can buy more parts that I need.
jeff1000man is offline
Old 03-02-2009 | 10:17 AM
  #47
Jeff, i want to do the upgrade together with bottom end earliest in summer or fall. the other thing is, that i will need the parts for two engines and i think you have parts just for one.
Old 03-02-2009 | 10:22 AM
  #48
Chances are you will have to accumulate to get this done.
THere are 2 long blocks out there that are for sale that need rebuilding.
Good luck
Old 03-02-2009 | 12:11 PM
  #49
454/365hp mags will burn about about 35 gal/hr at WOT
525sc's will burn about 50gal/hr at WOT
Griff is offline
Old 03-02-2009 | 02:06 PM
  #50
thats very close to me thoughts, because 50% increase of horsepower and 50% increase of fuel consumption sounds logic. i hope its not more.
4bus
7
07-05-2007 01:11 PM
RazorsEdge
Superboat
16
08-09-2006 07:42 PM
awsomethunder
8
07-13-2006 10:35 PM
guillermof
2
08-10-2005 02:24 PM
gene
2
01-09-2003 05:26 PM
