Need More Speed! (496Ho Content) >
Old 02-12-2009 | 08:39 PM
Originally Posted by CB-BLR
How much does the boat weigh?
Chris
About 22,000lbs (dry)
DeepBlue47 is offline
Old 02-12-2009 | 09:06 PM
CB-BLR's Avatar
Chris
You should go play around with this site to figure out how much hp you will need to go 55mph.
http://go-fast.com/boat_speed_predictions.htm
I entered in your boat weight at 23000 lbs and your top speed of 47 mph to come up with a constant.
I then plugged in 55 mph and solved for horsepower, and it spit out 1169 hp or about 585 hp per side in order to get to 55 mph.
I have found this site, and speed predictor to be very accurate.
Given your horsepower requirements to go 55, Whipple is the natural selection. They make a kit for your motor to take it to aproximately 620 hp per side which would take your top speed to aproximately 57 mph... or about 10 mph more than you are going now.
I have found the whipple kits to be very complete, and Dustin is the man when it comes to re-programming the stock PCM.
I would not hesitate in the slightest in recommending his products.
He is at the Florida boat show right now, but can be reached via phone most any weekday from 10am - 4 pm at 559-442-1261.
I am not associated with Whipple in any way... he is just that good of a guy in my opinion. He has helped me on innumerable occasions, while working on my own projects.
Chris
CB-BLR is offline
Old 02-12-2009 | 09:17 PM
Chris
Hey Chris,
Thanks very much for the site! I will be sure to play around with it. It sounds like Whipple (at least on paper) is a good fit for what we want to do.
Things are a bit crazy my end, so I'll try to call Dustin next week to touch base with him. I sent Whipple and e-mail the other day but never got a response, I forgot about the boat show haha. I feel less ignored now ;-)
Thanks again!
Old 02-12-2009 | 09:30 PM
[QUOTE=DeepBlue47;2799033]Haha....thanks.
What did you mean with HAHA ????
About the drives or the Condo ?! LOL
DareDevil is offline
Old 02-16-2009 | 04:20 PM
[QUOTE=daredevil;2799239]
Originally Posted by DeepBlue47
Haha....thanks.
Both...lol
I'm pretty sure I'd have to replace the drives because I can't see myself getting out on the water and giving the throttles a little bit of a punch every now and then
Old 02-16-2009 | 04:31 PM
Don't be afraid to go the Raylar route either. Ray has got his parts down to a sceince on the 496. The 103 kit costs about $6K and with the exhaust you have already upgraded to it will put you right where you want to be at around 560HP. I am sure he will chime in to give you some more information but he to is probably at the boat show.
Baja_man is offline
Old 02-16-2009 | 04:46 PM
KAAMA's Avatar
Its a Riviera M470 with twin 496 Mag HO's. This past winter I went ahead and put Dana Marine's Thru-hull exhaust on her and figured I would see how the season went. I didnt see any real gains (just great noise!) Thanks for any help guys
What RPM's where you turning at wide open throttle with the STOCK exhaust system?----and then did you see any RPM gains with the addition of new aftermarket Dana exhaust???
How about the midrange?---Did you notice any more "kick" (torque)or speed increase in you midrange crusing speeds?
In either case, I am glad to see that you added/upgraded to a better breathing exhaust system on your engines FIRST! Now, your engines are ready for the internal upgrades and possibly more bolt on upgrades!
Personally, I think I would skip the supercharger style of upgrade because your boat is WAY too heavy with those Bravo outdrives that have engines with superchargers. The torque comes in like GANG BUSTERS and you will have drive problems for sure! Unless of coarse you upgrade to a much stronger drive over the Bravo One.
I think Ray from Raylar would be good assistance to you on the engine stuff.
KAAMA is offline
Old 02-17-2009 | 09:42 AM
I've got some experience with setting up Whipples on a 400ss Formula. This boat had 500 efi and Bravo 3 X drives. Speed went from upper 50's to mid 60's. We then swapped the B3 for B1 XR drives. We gained a couple of mph with stock props. Then sent the props to Bblades for labbing and ultimately were able to break 70 mph. I can help you with setup and Whipple purchases if you decide to go that way. I've also done several Raylar 496's. I don't think the 525 Raylar kit would meet your goal though. BOth are very dependable. Keep in mind the Whipple requires 91 octane fuel.
Give me a call or email me. Bob 830 6935591 [email protected]
bobl is offline
Old 02-17-2009 | 06:04 PM
Originally Posted by Carder
Don't get new props until after you do your HP upgrades. Your current props will give good baseline numbers, and help estimate what final size/ gear ratio will be best. Are you currently using the 2.0/1 gears?
Carder
I am currently running 2.0/1 gear ration on the drives and have a prop pitch of 22....i dont know the prop size, but I have a part number if that is any help.
I am pretty sure the props need to be changed, but not sure to what...any thoughts?
How about the drives? I have seen many ppl talk about the 1.5/1 ratio, but I really have no clue regarding props and drive ratios. If you know of somewhere for me to find some info I'd love to read up about it and get a better idea.
Thanks guys
Old 02-17-2009 | 06:06 PM
Thanks for the info! You seem to have some great first hand knowledge so I will try to shoot you an e-mail to clear up a few things.
Thanks again
