Anyone using Big Chiefs?
#42
#43
Yes, only Ti on 12 degree heads like profiler, copper-berylium seats are the way to go, better heat transfer and corroision protection on the exhaust, have you ever tried cutting in a valve seat on alloy, it's very hard material. 20-25 $ per seat plus machining, most people don't understand the difference between the two. If you need to know the exact alloy makeup between intake and exhaust, I would have to look it up on the spec sheet.
#44
If you have the time, it would be great, who is your source on valves and seats? What do you use when they aren't 12 degree heads?
#45
Send them to Jimmy V
#46
Ferrea valves or if going custom Victory Valves for Ti, it wasn't cost effective for Victory, to do inconel and stainless in the the past.
#47
Good to see someone out there knows quality; Percision Products, in Arden, NC.
#48
BTW with the help on both threads (2 sites)
#49
Chuck at :Percision Products is great to deal with drink:
#50
Charter Member #40
Ran Del West intake and exhaust titanium's in some 14 deg's with 9.5:1. Ended up having problems on exhaust side and Del West said that with a compression ratio of only 9.5:1 I needed to get them out and go with a different valve as they do not like low compression ratio's. Higher compression no problem as apparently the exhaust runs cooler? Intake were fine.
