525 efi prop horsepower >
Old 04-21-2009 | 06:55 AM
looks like the higher the numbers merc can post,,the more they will chrge for the engine
TWIN-SPINS is offline
Old 01-29-2020 | 06:37 PM
If it's clear that the advertised hp is at the crank then they are underrated!
Old thread, I know, but good winter reading.
thirdchildhood is offline
Old 01-30-2020 | 11:52 AM
Must be really bored to revive this thread. But I do have some more data I can share. Most dyno shops including myself use a "standard" correction factor for testing. OEM use an "SAE" correction factor which is a couple of percent more conservative. So the HP comparisons everyone sees is more a difference of testing methods than of actual power produced. I recently rebuilt a couple of 525's. I dyno'd them before tear down and made 556 hp running all accessories and wet exhaust, using the Standard correction factor. I rebuilt them, did a mild bowl blend and used the small dome 502 pistons which added a couple of tenths more compression. With a recal of the ECU we made 581 HP. We also replaced the cam (because of damage) with Comps 525 replacement version. It appears to be a tiny bit milder than the Crane OEM cam.
Bob
bobl is offline
Old 01-31-2020 | 03:24 PM
Glad you did
Pismo10 is offline
Old 01-31-2020 | 03:37 PM
Bob
still 87 octane or?
Unlimited jd is offline
Old 02-02-2020 | 08:04 PM
Originally Posted by Unlimited jd
still 87 octane or?
The compression is about 9.2:1 ....
I DO fill up with premium on land but would top off with mid grade on the water if I had to ...
Doug
Boatally Insane is offline
Elite Marine
20
09-12-2008 05:28 PM
11-08-2006 06:07 PM
open wide
2
10-15-2004 08:10 PM
XCAV8
1
04-26-2003 02:27 PM
