fuel filter after regulator ??? >
Old 03-05-2009 | 07:48 PM
Default fuel filter after regulator ???
Hello,
I have a mallory electric fuel pump with a large filter before the pump. Mallory told me I do not need to run a filter after the regulator. I don't have any room between the regulator and the carb. Is anyone running without a filter between the pump and carb.
alecsammy is offline
Old 03-05-2009 | 09:31 PM
You have to be careful, Racor filters are meant to have the fuel drawn through them. If you try to push fuel through them in can vaporize and create fumes / vapor lock.
I just went through this set up on my old Chriscraft.
I dont think there is any issue with having an additonal inline filter just be sure you are using the right type.
the vig is offline
Old 03-05-2009 | 10:22 PM
when you say racor filters, do you mean any fuel water seperator?
tx911 is offline
Old 03-06-2009 | 08:26 AM
Originally Posted by alecsammy
Hello,
People run them in case the pump fails. Bad if your injected. Your running a carb so it's not as critical. I ran for years without one after the pump but I have both now.
kennyo is offline
Old 03-06-2009 | 08:42 AM
Default fuel filter
I'm a s-x dealer in detroit and you should run a filter before and after the fuel pump. All fuel pumps have moving parts inside and they wear off material. We helped out a customer that did not run a filter after the pump and was burning pistons. We found brass shavings in the injector filters on the cylinders that were damaged,it came out of the fuel pump.The cost of a filter is less expensive than a engine.
Jb-fse is offline
johnnyboatman
2
03-06-2006 05:48 AM
Rage
13
01-14-2006 05:53 AM
puder
8
08-11-2003 01:37 PM
liquid asset
11
03-17-2003 09:50 AM
