Volvo 496 runs only on one cylinderbank >
Old 03-14-2009 | 12:21 PM
Default Volvo 496 runs only on one cylinderbank
Hi
My Volvo 2002 496 runs, but only on one cylinderbank, maybe one cylinder is firing, and it is also running at a very high idle speed. what could be wrong ? any sensors ?
Erik
ae23 is offline
Old 03-15-2009 | 12:59 AM
Wink
You need to get a scan tool from Rinda Technologies in Chicago, Illinois, USA. You can then scan the engine for trouble codes and identify whats really wrong. Everything else is a hit or miss guess at best.
Best Regards,
Ray @ Raylar
Raylar is offline
Old 03-15-2009 | 11:06 AM
RAYLAR is right BUT DOINT JUMP YETon cars &boats I have found dad connection where the power wire to the splits to the injectoresI also havebad connections at the block (for the ECM)the conections may look good ,put doint trust it,tack it apart, and look,pull on the conecter, pull on the wire If I was not clear call me at the shop 240/687/5599 Tony
acaruso is offline
Old 03-15-2009 | 05:55 PM
bowtie's Avatar
It's probably in guardian mode. The most common cause on Volvos is the little temp sensors on top of the exhaust risers. Just disconnect the wires from them one at a time, it should pick up. The engine won't run on only one cylinder.
bowtie is offline
86RedRocket
18
06-27-2019 10:33 AM
ae23
0
03-14-2009 12:20 PM
ae23
1
01-08-2009 08:03 PM
MILD THUNDER
14
06-09-2005 12:03 PM
bn
4
01-15-2005 07:40 AM
