dyno result questions...... >
Old 03-27-2009 | 06:40 PM
Took a look at the sheet here, just says fuel psi. Nothing about air fuel ratio...
cloudmaster_321 is offline
Old 03-27-2009 | 07:25 PM
Throw a decimal point between the first two numbers and you have A/F...............Possibly.
hallj is offline
Old 03-27-2009 | 08:33 PM
No idea.......
Old 03-28-2009 | 05:23 PM
Does the sheet have the torque readings?
Does the torque follow the suspected a/f number.
To a point torque will increase as the a/f decreases numerically.
with a gasoline N/A motor you will usually see 12.8 a/f produce the most torque at a given load range.
Jeff
hallj is offline
RUSSSR1
2
06-04-2005 08:00 AM
tomcat
8
05-02-2005 08:52 PM
tomcat
9
07-26-2003 11:11 PM
bago Baja
5
12-16-2002 02:10 PM
