Cam help
Old 04-03-2009 | 10:03 AM
batty's Avatar
Default Cam help
Camshaft Identification Help
I have a cam I pulled out of a Merc 420 454ci engine. Its a hyd. Flat Tappet. as far as i know its stock, but cant firgure out any info on the cam. in between the cam lobes there is CMC GMC cast there then towards the back of the cam between the lobes there is a casting that says C 1 and on the back of the camshaft there is an engraved number. 951432 Is this a part number???
Anyone have any Ideas? Or know what cam this is? I need to replace this and would like to be close to the other motor.
Thanks Brad
batty is offline
Old 04-03-2009 | 11:02 AM
Thanks Brad
If nobody can identify it. I see your in Ohio, Theres a guy that I know that can run the cam on his machine and give you all of the numbers your looking for. He does this at alot of the swap meets. He is in N. Olmstead near Cleveland.
whoya is offline
Old 04-03-2009 | 12:32 PM
The stock 420 cam is a Crane 132561
http://www.cranecams.com/index.php?s...61&lvl=2&prt=5
Griff is offline
