Transmission cooler line size? >
Old 04-05-2009 | 01:52 PM
Brad Zastrow's Avatar
Default Transmission cooler line size?
Boat with 1450 hp and 1550 Bam transmissions rigged with AN -06 cooler lines from the transmission to the oil cooler on the bellhousing. Does that seem like a small line size or is that normal?
Brad Zastrow is offline
Old 04-05-2009 | 02:16 PM
RMPRam's Avatar
Seems small to me. I think I used -8 lines on mine.
Gary Kollofski
RMPRam is offline
Old 04-05-2009 | 02:26 PM
Biggus's Avatar
I believe Marc @ BAM requests -10 lines. -6 would be way too restrictive.
Biggus is offline
Old 04-05-2009 | 04:31 PM
Bam states -8 minimun. I have pretty much always used -8 and it has worked fine. -6 is too small. Also, do not use any check valves.
Eddie
Young Performance is offline
Old 04-05-2009 | 09:45 PM
Thanks for the replies. It was bothering me so much this afternoon I changed the hose over to -10. I had the hose and all the fittings. No check valves or thermostats.
Old 04-06-2009 | 06:28 AM
Mbam's Avatar
Offshoreonly Advertiser
#6 is too small - we do require #8 minimum
Mbam is offline
