Air Flow 101 - applicable to engines >
Old 03-22-2002 | 01:51 PM
Shooter's Avatar
Charter Member #300
OK, what about a blower motor and the rectangular ports.
BTW - "blow" is a figure of speach...
Shooter is offline
Old 03-22-2002 | 06:23 PM
TOMCAT, Good post , but static pressure is the force being exerted outward against the "port" walls or "pipe walls", it is not why there is flow but it is a result of the flow.
David Stotz is offline
Old 03-23-2002 | 02:14 AM
David - You caught me breaking one of my own rules, over simplifying. I didn't explain total pressure (TP). The energy expended in drawing the piston down can appear as either static pressure or velocity pressure. Static pressure can be either positive or negative with respect to the atmosphere; velocity pressure is always positive.
TP = SP + VP
So you can think of total pressure as the total energy put into the air in the pipe by the fan, pump or engine, and whether this total pressure appears as static pressure or velocity pressure depends on how much flow is allowed by the pipe. Ignoring other losses, the amount of flow is controlled by whether or not the pipe is open at the inlet.
In the case where the fan, pump or engine are drawing through the pipe, both total pressure and static pressure are negative, less than atmospheric pressure. Just for illustration purposes, assume that the piston has drawn down and the throttle is closed; there is no flow and therefore no velocity pressure, so total pressure and static pressure are the same, both negative, and VP is zero.
TP - SP = VP = 0
It is this static pressure that will cause flow when we open the throttle. Now open the throttle and flow begins. This means there is now some velocity pressure, but static pressure and velocity pressure still add up to total pressure (in this case total pressure becomes less negative).
This is the actual relationship between static pressure, velocity pressure and the total pressure (difference) created by the descending piston.
It's actually easier to picture this if the pipe is under positive pressure with respect to the atmosphere. I will try to post some diagrams that illustrate this.
tomcat is offline
Old 03-23-2002 | 09:00 AM
Airpacker's Avatar
Ok Tom,I think its time you took a holiday down south.The cabin fever has definately got ya.Great info but man do you need a boat ride
Airpacker is offline
Old 03-23-2002 | 12:46 PM
Airpacker - Cabin fever is right, there's still ice on the bay and we got 8" of snow yesterday! I can't take it anymore!!!
Tom
tomcat is offline
Old 03-23-2002 | 12:50 PM
Diagram #1 - from the Industrial Ventilation Manual - ACGIH
tomcat is offline
Old 03-23-2002 | 12:57 PM
Diagram #2 - The fluid in the pressure measuring tubes is water. This is where the pressure units "inches of water" comes from. Question: "Is it possible to have a pipe configured such that the SP measures zero and all the total pressure is converted into velocity?"
tomcat is offline
Old 03-23-2002 | 01:01 PM
kaamacat's Avatar
Tomcat......now this question does relate to air pressure (kinda), and oughta be a wiz for ya.
If I want to take a vac reading and coorelate to what powervalve I might want to run, what is the difference in vacuum between taking it from a runner vs the carb base. Or better yet, where is the proper place to take the reading.
...I'll give you about 10minutes max, that includes an answer and a chart. ..................... GO
Bob
kaamacat is offline
Old 03-23-2002 | 05:51 PM
At the carb base.
Old 03-23-2002 | 07:23 PM
David's right, the plenum averages the different and fluctuating vacuum in each runner. Chart? Do I use charts?
tomcat is offline
