93' 502 Oil Pan drain Plug Fitting ???? >
Old 04-16-2009 | 04:39 PM
Default 93' 502 Oil Pan drain Plug Fitting ????
I am pulling my engines out before the season and wanted to install a oil drain system from the drain plug on the Pan. (Not go through the dip stick anymore) Does anyone know the size of the threads of that fitting. ??? I think Merc makes a fitting with hoses doing the same for other engines.?? Does anyone know the part number and if the fitting wpuld be the same on my 502 Pan.
Thanks in Advance
cocktails is offline
Old 04-16-2009 | 06:50 PM
My 454 was metric threads, can't remember the pitch, sorry.
Ken
minxguy is offline
Old 04-16-2009 | 07:49 PM
Pismo10 is offline
Old 04-16-2009 | 07:52 PM
Went metric in 1996
Pismo10 is offline
Old 04-17-2009 | 06:19 AM
they are metric now, not sure when they switched, when I installed the new GM vortec big blocks I had to tap the plug threads back to american so I could reuse my crusader either side dipsticks..Rob
ezstriper is offline
Old 04-17-2009 | 08:04 AM
Originally Posted by Pismo10
Went metric in 1996
Then1/2-20 it is. That is what my '87 small block was.
Ken
minxguy is offline
