What is the oil capacity for a1999 502 MAG >
Old 04-17-2009 | 10:12 PM
Default What is the oil capacity for a1999 502 MAG
What is Mercery recommendations oil capacity for a1999 502 gen VI EFI MAG with stock oil pan and remote filter?
goebel1 is offline
Old 04-18-2009 | 07:36 AM
Pwrbt33's Avatar
It should be 7 quarts if you drain the oil out of a hose on the bottom of the pan. If you pump it out the dipstick it may only hold 6 to 6 1/2.
Pwrbt33 is offline
Old 04-18-2009 | 07:48 AM
I pump my 1997 502 mpi mags out of the dipstick and they take about 6 1/2 quarts to fill.
johnny b good is offline
Old 04-18-2009 | 02:07 PM
If all the old oil is out, its 8qts.
You need to fire the engine and circulate the oil after refilling, then recheck the level with the boat at the same angle as the way it sits in the water.
Griff is offline
