imco external steering >
Old 04-25-2009 | 05:07 PM
Default imco external steering
i have a 31 scarab and i just put imco external steering and the only problem i have is when you turn the wheel u get about 1 turn before the rams outside turn but when the finaly do it kinda just darts in that direction not a slow turn so wat causes this air if so whats the proper way to bleed it out
88scarab is offline
Old 04-25-2009 | 05:19 PM
obnoxus's Avatar
Charter Member #1171
full lock to lock turns should do it
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 04-25-2009 | 05:22 PM
i already tried that many of times any other ideas
88scarab is offline
Old 04-25-2009 | 06:45 PM
My thoughts on bleeding air is to treat it like hyd brake lines. either attach a bleeder or do it with a mate turning the wheel with a hose fitting loose (probably best to have the HP on the pump fitting loose) then turn the wheel steadily until the fluid comes out, when it comes out in a steady stream rather than with bubbles or spurts, while still turning the wheel to maintain pressure, tighten the fitting back up.
Would that be a wrong approach? I hope not becuase that's what I've been doing!
Is there another way?
Ghostrider is offline
Old 04-25-2009 | 06:55 PM
Is it a single or a dual ram system ???
If its dual ram,,,,make shure they are hooked up correctly,then open reservoir and fill up 3/4 of it ,turn on engine and then turn steering all the way to the end ( u will feel it ) at that point turn a little more like u are turning against press. check level and do the same thing the other way. check again and repeat until level does not go down anymore ,,,remember to turn slow otherwise it will not bleed and make a mess !!!!!
DareDevil is offline
Old 04-25-2009 | 07:30 PM
its a dual ram and i did that but if the lines were hooked up backwards would it still turn the rite way
88scarab is offline
Old 04-26-2009 | 11:37 AM
duunoit's Avatar
Ghostrider is right on this. Is this a FULL system with helm? If so, simply turning it back and forth will not get it done. There is probably too much hose in the L/R circuit that goes back to the helm. The pressure/tank circuit will self bleed by just running the PS pump. The lines at the rams need to be bled from both fittings. If you have dual rams, you need to do the fitting that is farthest from the helm first.
When you figure out which fitting is the farthest from the helm (lets say the IN fitting on the left ram), you need to turn the steering wheel ALL the way to the RIGHT, this will completely extend the left ram. Crack the IN fitting on the left ram, have a buddy start turning the wheel to the LEFT. Keep turning the wheel and leave the fitting open until the bubbles stop and you get a steady stream of fluid from the fitting. Close the fitting. Since the drive will be all the way to the LEFT now, move over to the IN fitting on the RIGHT ram. Crack it and have your buddy turn the wheel to the RIGHT until it stops bubbling. For good measure, do that whole process again. Once that is done, use the same idea going in the other direction.
duunoit is offline
Old 04-26-2009 | 03:43 PM
no this is not a full steering just the outside rams still have the cable and everything
88scarab is offline
Old 04-26-2009 | 09:36 PM
duunoit's Avatar
All that typing and racking my brain for nothin'
duunoit is offline
Old 04-26-2009 | 10:16 PM
W H A T ?????????????????????????
