Crane 731 cam >
Crane 731 cam
Crane 731 cam
Old 04-28-2009 | 09:07 AM
Originally Posted by Smitty
The 731 cam is a very good cam. Will run well and make good power. I ran one for 3 seasons.
Ditto. And YOU CAN run stock roller lifters. Check too be sure you're dogbones don't lift but mine worked fine. If you can't find one I highly suggest Bob Madera. I made 845HP in a 515" procharged engine with his cam.
kennyo is offline
Old 04-28-2009 | 01:01 PM
Smitty's Avatar
You can use stock lifters but you will need to check pushrod length. I have 2 sets of pushrods that I used with that cam and stock lifters. Get an adjustable pushrod tool and then tell me what length you come up with and I will check what I have.
Smitty
Smitty is offline
Old 04-28-2009 | 04:21 PM
Smitty - thanks. I guess I am torwn on using my existing lifters or buying new ones? The ones I have are stock with almost 400 hours on them. After I gave it some thought I am thinking I might change the springs and lifters, after all I am adding the Vortec supercharger. What dose everyone else think?
baja_brian is offline
Old 04-28-2009 | 04:32 PM
Change it as a package, Cam, Lifters, Pushrods, Springs. Use good components do not use OEM stuff.
jeffswav is offline
Old 04-28-2009 | 11:01 PM
Yes you are right. the Crane 731 is a big cam. I just spoke to Summit on the phone and the tech sait that the 731 is best suited for 4,000 to 7,200 RMP. This sounds awful high, Is he right? I am not sure if I have the RPM's for that. I was thinking I would run about 5,600 range?
The Summit guy is full of it. I ran a 731 cam in my 28 Pantera's 525SC/454ci and it was fine and by no means too big. It idled fine and I picked up about 100rpms over the stock cam. I spun it to 5300rpms. It made good midrange power.
Tell the Summit guy that hyd rollers don't like more than about 6000rpms.
Griff is offline
Old 04-29-2009 | 01:24 PM
Smitty's Avatar
Tell the guys at Summit to stick to cars. Boats are a whole different deal.
Smitty is offline
