cam recomendations????? >
Old 04-30-2009 | 07:43 AM
lake speed's Avatar
Default cam recomendations?????
Here is the scenario. I have a 25' eliminator that "HAD" 632 in it until the crank decided to break saturday and destroy pretty much everything. I am going back with a 10.5 to 1 632, dart 360 cnc ported heads that have also been finished by hand. single dominator 1195 on a port matched dart intake. the cam in the old motor was a solid roller n20 cam and I want to go with a hydraulic roller cam. any recomendations? the headers are injected at the last 10"s
I would like to buy a cam off the shelf as I dont want to wait for a custom ground cam. thanks in advance for any help.......
lake speed is offline
Old 04-30-2009 | 08:08 AM
contact Bob @ marine kinetics 585-654-8583, Rob
ezstriper is offline
Old 04-30-2009 | 12:51 PM
Smitty's Avatar
Call Bob Madera as mentioned above. You will get a better, more precise cam that will be ground exactly for your set up and it will cost the same or less than an off the shelf Crane or Comp cam.
Smitty is offline
Old 04-30-2009 | 01:03 PM
Give Bob a call. He can design a cam for your engine specs along with the lifters, springs & timing chain. I think it only took about a week to get the cam once I gave him the OK. I just got mine running, take a look at my post on "Roller Cam Upgrade".
jeffswav is offline
Old 04-30-2009 | 03:10 PM
He said he dosen't want to wait for a custom ground cam.
I would say Bob also, but that route takes a while. I'm glad I called in January
1BIGJIM is offline
